ZV7-T (transformer) - Page 53 - diyAudio
Old 10th June 2008, 12:43 AM   #521
Paper mache horn fabricator
carpenter's Avatar
I made the correction on my latest schematic layout. Cool, it raised the sine-wave upwards on the volt scale--should allow for a bit more input voltage without clipping the lower half of the sine-wave.
It's difficult for me to locate a large dual five volt supply, so I'm toying with a ten volt power supply with the additon of a virtual ground. I hope that someone will be kind enough to explain whether or not my attempt has merit.
Many thanks, guys.
John
I enjoy audio so much that I constructed a web site. I share my ideas at: www.inlowsound.com
Old 10th June 2008, 04:19 AM   #522
carpenter's Avatar
So, I made a few more changes:
Old 10th June 2008, 04:21 AM   #523
carpenter's Avatar
The sim says it's only a two watt affair, but that's what I want. Here's another graph:
File Type: png lu1014d transistor id-vds chart 6-9-08.png (85.8 KB, 120 views)
Old 11th June 2008, 05:25 AM   #524
carpenter's Avatar
Originally posted by Zen Mod
even better - use CCS as Papa like it - mosfet + little bjt
Hey Choky, how's this?
Old 11th June 2008, 06:46 AM   #525
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
wrong ;
you are loosing advantages of linearisation when CCS is in tail , complicating with series CCS-es and chokes
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 11th June 2008, 01:34 PM   #526
carpenter's Avatar
wrong ;
back to the drawing board for me........
Thanks, Choky!
Old 11th June 2008, 01:51 PM   #527
carpenter's Avatar
This seems to work, and if a bit more efficient:
Old 11th June 2008, 02:43 PM   #528
Zen Mod's Avatar
finding 6V xformers ( even SMPS ) isn't so hard , so it's easy to make +/- 6V PSU;
keep gates on gnd potential , common CCS on - 6 and chokes at +6
Old 11th June 2008, 10:26 PM   #529
carpenter's Avatar
To be quite honest, I'm trying to play with the parts in my junk drawer. Money's a little bit tight at the moment. I was hoping that my virtual ground idea would save me a couple of bucks. But, if you think that dual transformers are the way to go, I'll put more effort into finding a pair.
John
Old 11th June 2008, 10:35 PM   #530
Zen Mod's Avatar
John
make a sim or few with these voltages and observe
then decide ;
nobody is smarter than you , for your wallet
Using mains transformer as output transformer Elias Tubes / Valves 176 11th March 2013 09:35 PM
Modulation transformer for a driver transformer? ironradio Tubes / Valves 6 28th December 2008 05:05 PM
filament transformer vs plate transformer contaxchen Tubes / Valves 10 14th January 2005 10:43 AM
toroid Transformer as power Transformer for tube tone Tubes / Valves 7 11th February 2003 08:57 AM
toroid Transformer as output Transformer for tube preamp? tone Tubes / Valves 15 2nd February 2003 04:36 AM
Copyright 1999-2017 diyAudio
