ZV7-T (transformer) - Page 3 - diyAudio
Old 30th March 2006, 04:49 AM   #21
Magura is offline Magura  Denmark
Magura's Avatar
Default Re: Just the man I want to see!
Originally posted by carpenter
I'll explore air-core inductors. I can have them wound with a center tap.
Is there optimum size in wire gauge and in mH? My wire guy doesn't wind below 14 gauge. 16 is more cost effective...
Many thanks,
John Inlow
I made my inductors of 1.9mm wire. 1.9mm is the point where it turns too troublesome to work with VS. low resistance.
For 2*80mH you end up with a 20kg inductor, so you will need a couple of rolls of magnet wire
Magura
Everything is possible....to do the impossible just takes a little while longer.
www.class-a-labs.com
Old 30th March 2006, 05:06 AM   #22
Paper mache horn fabricator
carpenter's Avatar
Default 20 kilograms!!!!!!!!!!!!!!!!
I think I'll stick with my nice little 1000V/A Plitrons. Good grief, I'd need a wheelbarrow and a handtruck just to move the thing around.
God, I love you crazy guys!
Old 3rd April 2006, 12:05 AM   #23
carpenter's Avatar
Default ZV7-T coupled to a line array...
Can anyone tell me what it would take to coax this amplifier into handling a very low speaker impedance?
I'm considering the fabrication of a large line array--say 16 speakers per side. I'd like to keep these wired in parallel if possible.
Any thoughts?
John Inlow
Old 3rd April 2006, 12:12 AM   #24
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
Default Re: ZV7-T coupled to a line array...
Any thoughts?
John Inlow
just increase Iq to insane level
use several cascodes in parallel-'till xformer became too hot
then use bigger xformer
or buy bigger amplifier
or ,even better, buy bigger speakers with sane impedance
hehe-best of best - change hobby
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 3rd April 2006, 01:34 AM   #25
carpenter's Avatar
Default Choky, you put the smart in aleck...
I was thinking more along the lines of using those unused outputs of the current transformer as an impedance matching device.
I just wondered if the transformer can act as a step down transmission to drive insanely low speaker impedances.
John
Old 3rd April 2006, 01:46 AM   #26
Zen Mod's Avatar
Default Re: Choky, you put the smart in aleck...
John
"Choky, you put the smart in aleck...."
I didn't get it....
anyway-you're right about "unused outputs"....in fact-old scheme known to me from one sort of push-pull tube amplifiers where output xformer was connected between cathodes......
I just didn't know that you have unused taps on xformer...
and ratios are (OK-voltages are?) ?
Old 3rd April 2006, 01:57 AM   #27
carpenter's Avatar
Default don't know enough about transformers... bummer
The current supply transformer is Plitron's 1000V/A with 120/120 primaries with 50/50 volt secondaries. I'm guessing that this is a little more than a two to one step down.
wouldn't this double the current while halving the voltage?
John
Old 3rd April 2006, 02:30 AM   #28
Zen Mod's Avatar
Default Re: don't know enough about transformers... bummer
John
from top of my head-if you use 120+120 for 8 ohms ,then 50+50 is for 1,83 ohms
Old 3rd April 2006, 02:39 AM   #29
carpenter's Avatar
Default the schematic at the beginning of this thread...
It shows how the speakers are currently driven. What the schematic doesn't show is the unused 50/50 volt secondaries on the other side of the 120/120 volt coils. Does this change your feelings on the secondaries driving a 1.83 ohm load? Also, would the secondaries be series or parallel?
Thanks for taking the time to chat,
John Inlow
Old 3rd April 2006, 02:41 AM   #30
Zen Mod's Avatar
Default Re: the schematic at the beginning of this thread...
John Inlow
do not change or touch anything;
just connect these damn 2 ohm spks to 50-50 taps
Using mains transformer as output transformer Elias Tubes / Valves 176 11th March 2013 10:35 PM
Modulation transformer for a driver transformer? ironradio Tubes / Valves 6 28th December 2008 06:05 PM
filament transformer vs plate transformer contaxchen Tubes / Valves 10 14th January 2005 11:43 AM
toroid Transformer as power Transformer for tube tone Tubes / Valves 7 11th February 2003 09:57 AM
toroid Transformer as output Transformer for tube preamp? tone Tubes / Valves 15 2nd February 2003 05:36 AM
Copyright 1999-2017 diyAudio
