My JFET project
My JFET project
Old 11th March 2006, 10:48 AM   #1
bappe is offline bappe  Sweden
bappe's Avatar
Default My JFET project
Hi!
This is what i plan to put together when i get my hands on a few LU1014D´s.
BR,
Anders
Old 25th July 2006, 05:41 PM   #2
coloradosound is offline coloradosound  United States
I'm assuming this is a balanced design? Where are the inputs?
I'd really like to come up with a LU1014D design that can
drive my 4 ohm Carver Ribbons, maybe even with super-
symmetry. Would I need to parallel the VFETs and use something
rated higher than the IRFP240's?
Old 27th July 2006, 02:49 PM   #3
bappe's Avatar
The input is at the connection between the 100k and 100 ohm resistors at the jfet input. This one would have no problem driving 4ohm speakers.
BR,
Anders
Old 29th July 2006, 11:31 PM   #4
macka is offline macka
macka's Avatar
Anders,
Excellent concept,
I bit like a balance follower idea using the cascoded power Jfet.
Please keep us informed with your project.
Macka
Old 24th January 2007, 11:59 PM   #5
Anders,
Have you received your LU1014D s yet?
I have mine already and also have some 800 watt Astec MVP
switchers with two of the 24V 15A modules per chassis.
I couldn't tell if your rails are +36v and -36v or +36v and -3v?
I still think that because of the impedance that I will need
to parallel about 4 of the FETs so that they are biased at
the most linear point as in Nelson's Zv9
Anybody else know anything about the Astec MVP series for
audio?
Old 25th January 2007, 12:16 AM   #6
GRollins is offline GRollins  United States
It does not appear to me to be biased heavily enough to handle a 4 Ohm load well. That's not too difficult to fix, though.
Grey
Old 26th January 2007, 07:35 AM   #7
bappe's Avatar
Default Project progression
Hi!
The amp was built the way it is shown in the first post and showed real promise sonically, it was running a bit hot with the heat sinks i had laying around though. To tackle that problem i decided to choke load it. This dropped the idle power by 50% AND it sounds better to my ears. I have also built one more jfet amp that you can see below, this one is not a transconductance amp and it is also quite happy as high bias class-B amp (500 mA or more). It sound is not quite as relaxed as the other two but it has more "grunt" and drive and i am using it now for bass only. The one below is the class-A version, in the class-B version i have removed the 0.5 ohm source resistors and inserted a bias supply in front of the output stage.
Anders
Old 26th January 2007, 12:33 PM   #8
flg is offline flg  United States
flg's Avatar
A hybrid Circlotron Nice
Old 26th January 2007, 09:32 PM   #9
Looks good to me. Are the 100pF caps at the Gates of the LU1014Ds necessary?
Grey
Old 27th January 2007, 08:52 AM   #10
bappe's Avatar
They are not really needed whith the tube input stage, driven as a buffer from my signal generator they where so i kept them just in case.
Anders
My JFET projectHide this!Advertise here!
New JFET guitar preamp project jazzpeter65 Instruments and Amps 197 3rd May 2017 01:20 PM
Advice on new project- Mini-A w/ JFET or F4? winslow Pass Labs 5 18th January 2008 01:05 AM
Can I replace BF245C JFET with J201 JFET? bigmike216 Parts 2 7th December 2005 06:50 AM
JFET and ZEN Skorpio Pass Labs 1 6th December 2005 09:30 PM
