I came to think of this today.
![]() Of course cascode moddulation can be implemented. would it work? As its drawn it has a ultralinear feedback arrangement.
We live in a horizontal world, why use vertical topologies??? |
#2 |
The one and only
I believe it will work very well. I have a similar schematic which I
have yet to build.
#3 |
The circuit should have much more gain then ZEN9?
Do you have modelled it with SPICE? Regards |
#4 |
Thank you Mr Pass! Looking forward to it!
kekso22: I have not spiced it. I dont know how to. I dont know if it has more gain than Zen v9, but its a way to make a simple pushpull circuit. I just like the SRPP circuit Its simple and elegant.
#5 |
I think R10 should be a constant current source. It should work a lot better with a stable voltage accros R11.
#6 |
Or a cap around R11
Very cool circuit Circlomanen
#7 | ||
Johannes.
#8 |
#9 |
I think that R8 and R4 should be 33 ohms or something similar.
#10 |
Some friends of mine years ago tried a Fet based SRPP circuit, using Japanese and European semi such as 2SK and BF type, but they found many problems.
The only "working" Fet/SRPP schematics I'm aware of has been published on the Japanese mag MJ. The "secret" was the particular hi voltage Vfet used: 2SK79, made by Sony and non longer manufactured). I understand you circuit is different, but I think it needs to be tested carefully. |
| Are Srpp's Any Good (please Help) | soundbadger | Tubes / Valves | 6 | 17th October 2007 09:09 AM |
| To SRPP or not? | duderduderini | Tubes / Valves | 2 | 12th March 2007 03:01 PM |
| mu / srpp / or CF? | AudioGeek | Tubes / Valves | 9 | 24th April 2004 05:48 PM |
| SRPP is....? | peranders | Tubes / Valves | 8 | 19th December 2003 08:38 PM |
| Help with SRPP pre- | ktigerb | Tubes / Valves | 11 | 10th October 2003 10:40 PM |
| Page generated in 0.09486 seconds (81.29% PHP - 18.71% MySQL) with 10 queries |
