hi
i have an question that bother me" how many amp of current do i need if i have an aleph-x run in at 30 vlot +- power supply to makeit an class A? amp" 30 volt at fet |
#2 |
Paper mache horn fabricator
There's an excel program named: 1.xls
do a seach for it (diyaudio search button) then download and learn plenty of good stuff about the AX. Good luck, John |
#3 |
een ooievaar is geen konijn want zijn oren zijn te klein! |
#4 |
What a stud. I use that spreadsheet often. Thanks wuffwaff
John |
#5 |
hi
i just find out that i need like 15 amp to be called class a amp is that right ? for 4 ohm ar-limited 3 ? at 30volt but where i can get it ? |
#6 |
it will allways be class A. No AB possible! 30V is quite a lot for this bridged amp. I would go lower. William
#7 |
how to get it down?
i wire it already ? |
#8 |
You could use the 220vac primaries rather than the 115vac primaries for the 115vac supply in the US.
Just an idea. -David |
#9 |
good ideal i never think of it
thank |
| Page generated in 0.08494 seconds (79.51% PHP - 20.49% MySQL) with 9 queries |
