#51 | |
Anthony I will take 6 |
#52 | |
Anthony |
#53 |
Anthony,
What is the DCR of these inductors?
Philip "If you didn't make it with your own two hands, its not really yours". |
#54 |
You might also check out the prices on inductors at Zalytron,
I think ( the one and only) has already mentioned them but I will give them another plug. There price on a ERSE 14 gage air core in the 2mh size is $11.77 US and they only have a $50 minimum order. |
#55 | |
Anthony |
#56 |
Bob,
Thanks for the lead. Unfortunately, it has the same approx resistance (and in turn, same voltage drop) as the other inductor that is dragging the voltage down. The ferrite core one shows promise though, but I have never used one in PSU, only air cores. Any audible difference?
#57 |
I have one question about Aleph 5 power supply.
Mr. Nelson use 4x25.000uF for stereo amp. I'll use 2x69000uF/50V capacitor made by Sprague (36D). Are these caps will be enough for stereo Aleph 5 without additional inductors ??? I allready have 750VA rating toroid transformer, but it's not quite good (it's buzz) and I'll replace it with 900VA rating toroid transformer with 4x25V sec. This must be more that enough. ? best regards, LEON
Music is a part of my life, DIY is my life. |
#58 |
Leon:
You're in the green with those caps and toroid. Minimum is 600VA and 100000uF.
Mads K |
#59 |
Hello kirc,
Try to use the inductors in the power supply. They are well worth it to spend extra money on them, also I think that they are very cheap in Slovenia, like in Croatia. The 1.2 mH and up inductors should be used for the best results. You can use those that are normally used in the speakers crossovers. Best regards, Kristijan Kljucaric http://web.vip.hr/pcb-design.vip |
#60 |
So a 1kv for a stereo aleph 5 would be adequate?
ie. one 1kv transformer and assorted bank of caps would be adequate to run both channels of the aleph 5? Joel |
| Aleph P.17 Power Supply | Bengali | Pass Labs | 6 | 6th October 2008 06:24 PM |
| Aleph 30 power supply | jmmartins | Pass Labs | 2 | 28th September 2007 04:47 PM |
| aleph 1.7 power supply | jarthel | Pass Labs | 8 | 29th June 2007 04:20 PM |
| Aleph X power supply | Mach_Y | Pass Labs | 42 | 29th March 2004 08:43 PM |
| Aleph-4 Power Supply needs help | ruangrit | Pass Labs | 1 | 25th January 2004 05:38 AM |
| Page generated in 0.10781 seconds (79.95% PHP - 20.05% MySQL) with 11 queries |
