Aleph 5 Power Supply
Old 11th November 2002, 08:03 PM   #11
hifi is offline hifi  Sweden
you can use as much capacitance as you want... but the caps will probobly donīt last long if you use 41V rails over 40V caps if the AC get up a bit then you might have ~45V over the caps and that they will most certainly not like.
Btw...keep your eyes well clear from the safety vents on the caps!!!!
/micke
Old 11th November 2002, 08:53 PM   #12
kristijan-k is offline kristijan-k  Croatia
Hello,
The 40 V capacitors would work ok with 29 V transformer and with Aleph 5 amplifier.
The voltage over the capacitors would be lower
when the power supply will be under load ( Aleph amplifier
connected to it ).
Try to use inductors in the power supply, they will also slightly lowered the PS voltage.
It would be even better to keep entire head away from the capacitors when you are not 100% shure about their specs and limits.
Best regards,
Kristijan Kljucaric
http://web.vip.hr/pcb-design.vip
Old 12th November 2002, 11:35 AM   #13
martinschki is offline martinschki  Austria
Hi Friends!
Can you tell me the Type and the Value of the Choke if I want to do it that way. This should bring down my Voltage a little bit so that I can use my 40V Caps!
This is exact the layout for MY Power Supply (Thanks Kristijan)
Thank you very much!
Martin
Old 13th November 2002, 01:29 AM   #14
trigon is offline trigon
trigon's Avatar
Yes martinschki, you can go with ~4 mH (3.9mH) air-core and you can lower the voltage 1-2 V
I've purchased those capacitors over the e-bay recently and I am not sure if anyone can tell me if they are worthy. For 12pc $50
As well I can't tell what the production date is on them from code?, anyone knows?
Old 13th November 2002, 01:30 AM   #15
trigon's Avatar
yet another pic
Old 13th November 2002, 07:14 AM   #16
rendisha is offline rendisha
Default Production date
It seems like 39th week of 1987.
Old 13th November 2002, 03:55 PM   #17
trigon's Avatar
Oh Noooooooo Is this mean that I can't use them, douughh.
The seler mentioned that they are new and never used, but I will try to recondition them, lets hope that works, becouse they seem to be nice and tall which is what we need for PS in any stronger amp. There should be 6 in one mono block = ~250.000 uF
Any idea haw safe would be to use them.
Thanks rendisha
Trigon
Old 13th November 2002, 04:05 PM   #18
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
Aleph 5 Power Supply Send a message via AIM to Peter Daniel
There's no danger in using them.
To order kits contact me through forum mail.
Old 13th November 2002, 04:24 PM   #19
PedroPO is offline PedroPO  Portugal
PedroPO's Avatar
Send a message via ICQ to PedroPO
If they work that ok I guess.
the other day I tested a 60yrs old valve radio. The caps were at least 60 yrs(analysing the layers of dust) and it worked just like new!
Pedro Oliveira
Old 13th November 2002, 04:45 PM   #20
trigon's Avatar
Thanks guys. I am going to give tham a try.
Trigon
Aleph 5 Power SupplyHide this!Advertise here!
Aleph P.17 Power Supply Bengali Pass Labs 6 6th October 2008 06:24 PM
Aleph 30 power supply jmmartins Pass Labs 2 28th September 2007 04:47 PM
aleph 1.7 power supply jarthel Pass Labs 8 29th June 2007 04:20 PM
Aleph X power supply Mach_Y Pass Labs 42 29th March 2004 08:43 PM
Aleph-4 Power Supply needs help ruangrit Pass Labs 1 25th January 2004 05:38 AM
