hi
My aleph 3 is in good progress my overbuild power supply is: 68000uF+1.2mH+68000uF+1.2mH+68000uF ripple with 4A test: 500mV on C1 50mV on C2 5mV on C3 my new idea easy to do just transfer 2 wire for bigger ripple but maybe normal ripple but is it a good idea for better crosstalk and stereo image ?? :-) thanks |
#2 |
I m suprise nobody try this setup with good, bad or neutral
result |
#3 |
maybe your post isnīt that clear? Do you want to make a stereo amp with just one transformer, one bridge and one C1 and after that separate them with two Līs and two C2? This should work gine although I would choose the chokes a bit bigger (1.8-2,2mH). William
een ooievaar is geen konijn want zijn oren zijn te klein! |
#4 |
hi wuffwaff
"maybe your post isnīt that clear?" very possible my english is so so yes 1 transfo for aleph 3 both channel thanks for your advice but i can t change for bigger choke because my power supply is build now do you think there is a sound improvement to do this or my first design CLCLC is the way to go thanks |
#5 |
personally I always prefer double mono power supplies so I would opt for the second sollution where thereīs some kind of separation between channels. I never tried a stereo supply on an Aleph though, only on class AB amps. William
| Water-cooled Aleph idea | MEGA-amp | Pass Labs | 70 | 12th March 2011 12:52 AM |
| One Idea from PASS's ALEPH-L | DarkHorse | Solid State | 4 | 10th October 2005 01:37 AM |
| A DC servo idea for the Aleph-X | metalman | Pass Labs | 4 | 5th October 2005 09:10 AM |
| I have an idea but I need advice about the 15 coax | Cal Weldon | Multi-Way | 2 | 9th February 2005 05:21 AM |
| small Aleph idea | wuffwaff | Pass Labs | 4 | 22nd August 2002 07:14 PM |
| Page generated in 0.07231 seconds (81.74% PHP - 18.26% MySQL) with 11 queries |
