Hello Mr Pass, and thank for your nice devices
, and your worksI have a question, is it possible to put IRFP150 in the Aleph 2 's output stage (normaly irf244)? Thank you, and sorry for my bad english ( I'm French ), MrJean Baptiste. |
#2 | |
I'm not exactly Mr. Pass (only difference is that I have more hair and ,mostly,less mustaches yes-you can use IRFP150 ,you can even use one 150 instead two 244-but safest bet is just use head for head
my Papa is smarter than your Nelson ! tnx to thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
#3 |
The one and only
Since the Aleph 2 had 6 in parallel on each bank, with the
IRF150 you could easily go to 4. I think that would give better bandwidth than 6, as the IRF150 is a fatter part with higher current, dissipation and capacitance. |
#4 | ||
But I'm not a light in english Quote:
![]() I think that one irfp150 can replace three irf244. An irfp150 can supply 4 Amp at near 45V supply voltage and 180W max power dissipation VS irf 244 can supply 2.5 Amp at near 45V supply voltage and 125W max power dissipation. I think the output power will be up (more current availaible with irfp150).My worry was to know that irfp150 can support the 45V's power supply for a long time and if it was nessessary to adjust the bias in the Aleph two in relation to the new output stage. ![]() Good night. Jean Baptiste. |
#5 | |
"head by head" -I mean with that -most secure way is to use same amount as 244s......but-I resume that NP answered clearly to your question(s); anyway-for these mosfets, try to not burn more than 50 W in each of them,unless you go with heavy water cooling......you know-hot spots on heatsink,etc........ another anyway- always use some sort of DC speaker protection
#6 |
Hello choky, hello Mr Pass, and I'm very honoured to talk with you.
I'm agree with you Mr Pass, the bandwidth is more larger with ifrp 150 if you put six instead of twelve irf244, I think that come from of less capacities of mosfet in parallel. Choky, I use a capacity at the output of the amplifier I just use the Aleph two for medium tweeter (pure class A for them) and I use Symmetrical amplifier for Bass speaker (a lot of watts with symmetrical My drivers are Focal 38 WX for Bass, Focal Audiom 6WM for Midrange and Aurum Cantus G2 as tweeter. Passive filter between mid and tweeter, and active filter between bass and mid/tweeter. Before, I had builb a zen, very good sound about them. |
| First version Aleph 0 (Null, ZERO, O, Os, 0s) versus later Aleph versions | tiefbassuebertr | Pass Labs | 13 | 27th April 2012 02:13 AM |
| Aleph (Single Ended) + Larvadin (no Memory Distortion) = Ultimate Aleph? | tiefbassuebertr | Pass Labs | 17 | 9th January 2012 02:10 PM |
| Mini Aleph Board & Aleph 2 Parts List | gpsmithii | Pass Labs | 3 | 16th January 2010 03:58 AM |
| First version Aleph 0 (Null, ZERO, O, Os, 0s) versus later Aleph versions | tiefbassuebertr | Pass Labs | 0 | 6th August 2009 11:11 AM |
| PCBs for Aleph 2, Aleph 3, Aleph 4 and Aleph 5 amplifiers | kristijan-k | Swap Meet | 64 | 12th September 2002 07:55 AM |
| Page generated in 0.09382 seconds (80.21% PHP - 19.79% MySQL) with 10 queries |
