I have built an Aleph30 and the +v side of the PSU is .6vdc higher than the -V side under load for 2 channels. I'm using a single mini-Aleph PSU board from Brian using a CRC design. Under load the trafo is vac levels are the same for both sides. I built a second PSU with different parts of the same spec, but I'm getting the same results. I imagine the +-V should be the same values correct? The amp sounds incredible, even with the .6vdc difference. I was thinking of adjust the R to a slightly lower resistence value to bump up the -v value to match +v. Any thoughts on the root cause? Thanks! -David |
#2 |
Are you measuring the voltage on the first C or the second? What is the R? Does the R measure the same on both sides?
GL |
#3 |
The voltage difference is consistent with every stage in the CRC chain. I'm getting 20.2VAC off the trafo, 25.4 and 25.9 off each DC side of the bridge rectifer. The .6vdc difference is consistent before and after each stage of the CRC.
-David |
#4 |
It seems that your center tap is not quite in the center.
MikeW |
#5 |
David,
Mike could be right. So make sure that you have 20.2V between each secondary leg and the CT. If you do then the only thing I can think of at this point is to check the diode drop voltage across each diode of the bridge with your multimeter. The .6 value is really suspicious looking - being one diode drop. It seems unlikely that the problem is with the diodes but I've had stranger things happen. Good luck. Graeme |
#6 |
Well.... I found the problem. My trusty old DMM was off calibration.
Just took delivery of a new B&K 5360 and the difference between the +-Vdc sides of the PSU was actually .1vdc. I'm not going to worry too much about a .1vdc difference. Thanks for the help! -David |
#7 |
Actually after letting the amp warm up properly I measured a PSU +-vdc difference of .01 volts; -25.03 and +25.04.
Hope this is OK. -David |
#8 |
Hi David,
Glad to see you found the problem. Your supply voltages look fine. The .01V difference can be ignored. Graeme |
| 6VDC Wall worts, 2 amp... | chipco3434 | Chip Amps | 2 | 11th December 2007 04:10 AM |
| Help Aleph30 | Kooka | Pass Labs | 9 | 18th February 2007 02:03 PM |
| 6Vdc from 6,3Vac | resident | Tubes / Valves | 21 | 5th April 2005 01:06 PM |
| Aleph30 very very hot | arold19 | Pass Labs | 7 | 12th February 2005 01:55 PM |
| 1 Ohm For Aleph30 | gema | Pass Labs | 2 | 30th May 2002 07:40 PM |
| Page generated in 0.09255 seconds (75.32% PHP - 24.68% MySQL) with 10 queries |
