New Aleph 5, questions
Old 22nd February 2006, 05:54 PM   #1
gianc is offline gianc  Canada
Default New Aleph 5, questions
Hi everyone,
Iíve finally completed my Aleph 5, everything seems to be working fine. I have a question concerning a unique attribute of my amplifier. The transformers, one for each channel, are rated as a 46 volt center tap, 750 va 240 volts. So connected to a 120 volt source I get 23 volts, which is a bit low for an Aleph 5. The voltage is + and - 33 after the rectifiers, and 29 .5 volts after a CRC power supply arrangement. (each channel has 100,000 uf supply). Currently all component values are as per the schematic. My question is should some of the resistor values be modified from the standard values for the lower rail voltage? Also, is it OK to have the grounds from the power supplies floating, not connect to the ac input to chassis ground? There is a little less hum connected this way.
The amp sounds great, actually better than I had hoped for. Also, the heatsinks seem to be working great, around 45 degrees once it stabilizes, this has me wondering if the lower voltage transformers were a mistake.( bought cheap as surplus) Would it make sense to purchase a new single transformer of a higher voltage to increase to output power? Say 1 KVA 30 volts.
Old 22nd February 2006, 07:23 PM   #2
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
oh,man-just stop thinking and give us some more pictures!
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 22nd February 2006, 11:03 PM   #3
ok, here another pic. I'd post a few more but it seems that I will only be able post one per reply.
Old 22nd February 2006, 11:15 PM   #4
mastertech is offline mastertech  Australia
Banned
gianc
the engineering of your amp is as good as np's
well done
cheers
Old 22nd February 2006, 11:18 PM   #5
Zen Mod's Avatar
look and finish are extraordinary.....
some innard pics?
btw-look that you have wrong type of XLR on back?
Old 22nd February 2006, 11:52 PM   #6
Here is one of the inside, before completion.
Old 23rd February 2006, 12:30 AM   #7
MikeW is offline MikeW  United States
MikeW's Avatar
Default Ground
Use a CL-60 thermistor from star ground to chassis ground.
MikeW
New Aleph 5, questionsHide this!Advertise here!
questions about aleph 3 pinial26 Pass Labs 12 19th November 2007 09:53 PM
Aleph 30 questions needtubes Pass Labs 15 2nd November 2005 06:22 PM
more aleph 2 questions Mattyo5 Pass Labs 19 19th February 2005 11:51 AM
Aleph p 1.7 questions? bbakota2000 Pass Labs 11 14th March 2004 01:50 AM
Aleph 2 questions loovet Pass Labs 2 3rd February 2003 12:04 AM
Copyright ©1999-2017 diyAudio
