It may see an odd question but can anyone confirm if the Aleph has an inverting or non inverting output referenced to the input signal?
Macka |
#2 |
Hi!
Since his output stage isn't a follower it must be non-inverting (I think).
Let's make something special |
#3 |
Surely this is governed by the number of gain stages in the amp, each one providing a nominal 180 Deg. shift or 'reversal'. If so, Aleph 30 with 2 stages is non-inverting, but some of the earlier Alephs (IIRC, but I cannot access the schematics now to check) had 3 stages, in which case they would be inverting.
Bob |
#4 |
Account Disabled
Arr . . .
Aleph is too complicate for me . . . Anyhow, if I see the feedback line from the output, it is the non-inverting feedback. The output signal has the same sign with the input signal applied to the non-inverting input. jh |
#5 |
The amp, taken as a whole, is non-inverting.
The output stage is inverting. The front end, being a differential, can be hooked up to be either inverting or non-inverting. In this case Nelson chose the inverting hookup. The signal comes in, inverts going through the front end. Now it's "upside-down." Then it goes through the output stage and gets flipped once more, making it "rightside-up." Grey |
#6 |
Hi Grey,
Is my above recollection right that one (some?) of the earliest Alephs had 3 amplifying stages, and were accordingly inverting? I had only downloaded the A30 details, and, of course, Nelson has needed to remove the other circuits from prying eyes. Regards,
Bob |
#7 |
MikeW |
#8 | |
Lightning In A Bottle
His 1st gen Alephs like the 0 and 1, although having three gain stages is also non-inverting as the 3rd stage is a bunch of paralleled followers and does not invert the output of the 2nd stage. The input is a diff pair with output taken from the drain inverts then the 2nd is a voltage gain stage will revert back to the same phase as the input signal. Allan
Matched Toshiba FETs Warpspeed CE http://www.diyaudio.com/forums/vendo...ml#post2357988
#9 |
Hi Allan,
Thanks a lot for this clarification. I was right about the 3 stages then, but my memory let me down on the topology details. Tries hard, could do better, only 5/10! Nelson spoilt us all, maybe for too long, and I guess I took it for granted that these details would always be available on his site. It was a really sad day when I saw that Nelson was forced to remove his schematics, but I fully understand why he did this. I just wish I had downloaded them all ages ago, when they were available. Regards,
Bob |
#10 |
Thanks guys for all your replies.
Macka |
| sonic differences between inverting/non-inverting LM4780 VS both non-inverting LM4780 | jarthel | Chip Amps | 5 | 19th July 2007 01:37 PM |
| Aleph-phase lag with non-inverting input | jupiterjune | Pass Labs | 38 | 21st February 2007 05:05 PM |
| whats the difference between inverting and no inverting | mikee55 | Parts | 1 | 7th January 2007 11:36 PM |
| 'Chibi' phase inverting mod. | IpsilonSound | Digital Source | 73 | 26th July 2004 02:58 PM |
| Bridged/Stereo, w or w/o servo, inverting 3886, inverting buffer PCB | Alexander Rice | Chip Amps | 9 | 27th March 2004 07:53 PM |
| Page generated in 0.09526 seconds (80.75% PHP - 19.25% MySQL) with 10 queries |
