#21 | |
hehe-nice to see that your mom looks better than you ![]() spending some time with parents is always more and more valuable ,as years going by.......... now,I just wait to see steen's pics here.........
my Papa is smarter than your Nelson ! tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
#22 |
Account Disabled
You guys . . . too noisy . . . always when I sleep . . .
![]() Why no this way . . . ? jh |
#23 | |
hehe magical eraser you miss one black spot under the source of Jfet....... ![]() no SRPP no Mu folower plain ole cascode less gain........ more distortion.... I have no doubt that steen will try this too and let us know what is more pleasent to ear.........
#24 | |
Who is driving Q5? ![]() I second Choky... |
#25 | |
Account Disabled
![]() jh |
#26 | |
Ah ok, the Drain and Gate are at the same voltage.... Source sits at about 4 volts less ... the 220uF cap averages out the rimmple at the gate ... but what happens if rimmple becomes 1Vpp before the Drain ... the limmited Drain-Source voltage will limmit the effectiveness of this cap-multiplier arangment.. that's just a waste ! I think a voltage-divider (1 resistor to ground), ensuring at least 5 or 5.5 volt drain-source would enhance the performance of this circuit significantly... 1 resistor could make a lot of differnce here man! I a real BJT cap-multiplier, such a voltage divider isn't nessecary because the base-current will cause a voltage-drop allong the base resistor, providing room for some ripple before smoothing...but with a MOSFET , no gate current, so no voltage drop .. |
#27 | |
Guy's, thanks a lot for all the input
If you look at the circuit (regulator) You will see that it is a copy of the Zen regulator. Only thing missing is the zenerstring from R8 to ground. I also have some big BJT's that I could put in, if that is better. Steen
#28 | |
We could use some of that weather here in Denmark right now. Its all grey and cold here.Steen
#29 |
parallel to C3 a 15K resistor... ...
#30 |
and don't worrie about it to much... but it looked like a wasted oppotunity to me that's all .... MOSFET is fine is that position, for BJT you may have to change more values so just leave it the way it is...
... allthough a BTJ would give you 3 or 4 more Volt output......
| Improving the capacitance multiplier | Mr Evil | Power Supplies | 7 | 17th September 2011 11:00 AM |
| Capacitance Multiplier PSU | Ted205 | Chip Amps | 3 | 2nd March 2009 01:27 PM |
| Capacitance Multiplier | Kinnja | Solid State | 2 | 13th January 2008 08:12 PM |
| Capacitance Multiplier for A5? | siouxiebuff | Pass Labs | 3 | 21st January 2006 04:27 PM |
