I'm about to embark on a multi-channel BOSOZ preamp project. I'm heavily inclined towards Erno Borbely's balanced single-ended kit. Ultimate goal is to have a nice multi-channel system for DVD-Audio, SACD, etc., but that still does same quality for 2-channel.
The DVD player I use already includes Dolby Digital and DTS decoders, and features 5.1 analog outputs (single-ended). I still need to work out some of the details on how many switched inputs I need, how to control volume, etc. So far, so good. However, there are some analog sources that are encoded with Dolby surround, such as VCR and some TV broadcasts. For these Dolby Prologic II seems to be the preferred route, which presents a bit of a conundrum. Ideally, I'd like to have a stand-alone decoder which I can feed into the BOSOZ pre. Decoder IC's that perform this are sold only to Dolby licensees. What is commonly done to address this? What is the "best" way? I can envision a couple of approaches, each with their own pros and cons: - Rotel pre/pro -- criticized at length in the solid state forum; other makes usually include an FM tuner - PC-based solution -- this gets expensive with a quality sound card with analog inputs. - AV receiver -- I already own a nice FM tuner and amplifiers - Meridian 561 or 568 w/ DPLII upgrade ($$, but possibly most elegant solution) Any helpful suggestions would be most appreciated. Finally, I'm under the impression that although the original Dolby Prologic was an analog matrix decoder, the current method with DPLII is 2-ch analog in - ADC - signal processing - DAC into 5.1 channels. Is this correct? Thanks and regards, Rob |
#2 |
Hello,
you could buy an AV receiver that has 5.1 (or more) analogue outputs and not have to use the amps that are inside it. Although the 5.1 outputs might of allready gone through the recievers internal pre amp and volume control circuits, which isnt so good. You could of course take it appart and find where the 5.1 comes out of the surround processing chip and send that to your own pre amp. You should try some searches in the digital forum because people have tried this kind of thing before. Good luck Mark |
#3 |
What about using a DVD player with the surround decoding built in, and hook it up to your DIY preamps. Look at the Jolida 700. It has balanced out for all channels.
-David |
#4 |
I thought that was what he was doing except he wanted to have some dolby prologic2 encoding from an analogue source as well. As far as I know a dvd player wont do this.
#5 | |
I'll be using the DVD for decoding, which will output 6 channels to the BOSOZ. However, this leaves a gap for another other source type. Today, that's Dolby encoded TV, radio, and VCR materials. Tomorrow, it's Dolby Digital encoded materials from satellite or cable sources. The other option I'm mulling over is an Audio Refinement Pre2DSP. |
| What speaker/amp system is right for integration to a wingback chair???? | jinglebird | Multi-Way | 6 | 25th March 2009 10:18 PM |
| Multichannel Stereo System wattage per channel | EWorkshop1708 | Solid State | 11 | 28th February 2008 01:57 AM |
| Sub integration | JRKO | Subwoofers | 28 | 13th September 2006 09:29 AM |
| Running a Balanced System, With Twisted X-BoSoZ | jleaman | Solid State | 1 | 29th May 2006 05:16 AM |
| sub integration with fostex | regal | Full Range | 4 | 19th July 2005 04:08 PM |
| Page generated in 0.07980 seconds (79.50% PHP - 20.50% MySQL) with 10 queries |
