Pass X250 concept ?
Pass X250 concept ?
Old 15th February 2006, 08:19 PM   #21
acaudio is offline acaudio  Germany
Hi guys,
nice to see that the discussion is again flamed up.
My circuit with that Jfet cascode had, so far as I can remind, absolute no DC offset. I was running it without any capacitors in the signal way. I can agree Cheff, the sound was pretty well fast with deep bass. In the pas time I was on weight up what better, Aleph P or this. The time should show us. My project is on ice, but Ill continue as soon as my horns are build.
Good luck!
Adam
http://www.acaudio.de
Old 15th February 2006, 08:37 PM   #22
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
Pass X250 concept ?
Those are particularly nice horns. I take it those are FE166 ES?
Old 15th February 2006, 08:46 PM   #23
Thank You Mr. Pass!
Im using FE206E, driven by F1.
Best Regards
Adam
Old 15th February 2006, 08:50 PM   #24
The one and only
Pass X250 concept ?
I was fooled by the magnet size
Old 16th February 2006, 04:11 AM   #25
ANALOG GUY is offline ANALOG GUY  Malaysia
Send a message via MSN to ANALOG GUY
Default My completed schematic
1.Balanced source. (convert from Function Generator)
2.Balanced input module without de/increse gain.
3.Se input module with 10k potentiometre
Many guys mail me about my posted @ solidstate, Yes it's same schematic.
I have some problem with simulation when I use ZVN/P 3310 instead IRF610/9610 it's has more DC out on (drain+drain) output (0.5-1V) or I'll change source resistor from 1k to 221 ?
Help me please,I used 10.48mA each IRF610/9610.....too much ?
analog guy
Old 17th February 2006, 01:11 PM   #26
CheffDeGaar is offline CheffDeGaar  Europe
CheffDeGaar's Avatar
Just a few pics of the prototyped beast :
The "whole" setup, quickly breadboaded, wires everywhere, and absolutely no noise
/Cheff - Falling feels like flying, until you hit the ground
Old 17th February 2006, 01:13 PM   #27
A closer look...
Old 17th February 2006, 01:17 PM   #28
Top of the pops...
Old 17th February 2006, 01:33 PM   #29
lumanauw is offline lumanauw  Indonesia
diyAudio Moderator Emeritus
lumanauw's Avatar
Send a message via Yahoo to lumanauw
Is there any way to not-use K389-J109, replacing with other "easy to get" transistors, without sacrificing the performance?
Old 17th February 2006, 01:40 PM   #30
Haven't tried, so can't tell about better or worse performance. And you'd better match the fets.
Pass X250 concept ?Hide this!Advertise here!
Pass X250.5 right channel hum problem georgehifi Pass Labs 36 24th June 2015 10:19 PM
Pass X250+ Wadia martev Pass Labs 4 6th August 2009 08:44 AM
Lower the gain on a Pass X250.5? aljordan Pass Labs 10 8th January 2009 08:26 PM
pass x250.5 a little defect... kyrochan Pass Labs 10 30th May 2006 11:19 PM
Pass X250.5 question for Nelson georgehifi Pass Labs 4 15th March 2005 07:37 PM
