Old 6th November 2002, 04:53 PM   #1
www.audiohobby.com
Default Inductors, Lightbulbs As Current Sources
I've seen a number of single-ended designs in old solid state circuit textbooks which employ an inductor as a current source for the output rather than a resistor or active current source.
1. Would anyone be willing to offer an explanation for this approach? Is the idea to present a low impedance at audio frequencies? How would one calculate the appropriate inductor value?
2. As many of the inductor values I've seen in these old circuits are large, would it be possible to use a smaller inductor in series with a lightbuld ala ZenLite?
3. Is the larger inductor in ZenLite (power supply) used because the lightbulb itself is intrinsically noisy or because it presents a low impedance to the power supply.
Your advice is most appreciated. As I've been unable to divine the ansers from the old texts.
Mike
Old 6th November 2002, 05:39 PM   #2
The one and only
Nelson Pass's Avatar
No, we want a high impedance at audio frequencies.
Inductors work great. I have built a Zen with a 1 Henry
air core coil (...alright, a spool of magnet wire) and it had
about 40% efficiency and good low distortion. Of course it
has very low resistance, and so the Zen's original bias
network cannot be used to set the DC current.
As seen in ZV1, light bulbs work pretty well too, but at much
lesser efficiency.
Old 8th November 2002, 02:51 PM   #3
www.audiohobby.com
Thanks Mr. Pass
I like the spool of magnet wire idea.
Old 8th November 2002, 03:19 PM   #4
Banned
what is magnet wire?
Old 8th November 2002, 03:33 PM   #5
Banned
Light bulbs are used in the telephone industry as current limiting devices. But they do not like contiuous DC being passed through them. Unless you like replacing them frequently.
Jocko
Old 8th November 2002, 04:34 PM   #6
Jocko
I had always thought that Lamps run better & longer with DC. Here in Detroit We have Tommy Edison's original Light(Running on DC) still running. There were even quite a few "Add-On" diode sets for consumer lamps a few years back. I also thought that much of the power used in the telecom industry was still AC.
Anyone know about this??
Tall Shadow
Old 8th November 2002, 06:11 PM   #7
The one and only
I haven't had any problems, but then I have run them
very much below their ratings.
Old 8th November 2002, 06:23 PM   #8
paulb is offline paulb  Canada
Default Re: Inductors, Lightbulbs As Current Sources
Could the designs be referring to RF circuits?
Old 8th November 2002, 06:43 PM   #9
www.audiohobby.com
Paul:
No, they're audio circuits. I've seen them in very simple demonstration circuits in old transistor books. I guess the idea didn't have much appeal because of the size of the inductor required since, from a cost and weight standpoint, a 1 Henry inductor doesn't offer much over a transformer-coupled output.
Of course, this is of little consequence to us fanatics!
Mike
Old 8th November 2002, 07:03 PM   #10
halojoy is offline halojoy  Sweden
On Hiatus
Default 70% nom voltage = 100 times longer life
LIVSTID= lifespan
LJUSSTYRKA= strenght of light
ARBETSSPÄNNING= work voltage
MÄRKSPÄNNING= mark voltage (nominal)
STRÖM= current
the picture is from www.elfa.com pages with facts
It is on how the lifespan in ordinary lightbulbs correlates to working voltage
Pass Son of Zen w/current sources (etc.) GRollins Pass Labs 87 15th May 2006 05:35 PM
Current Sources vinay Pass Labs 1 19th March 2005 04:23 AM
Op Amp based current sources Kevinbd Solid State 1 3rd October 2004 07:18 AM
Aleph P current sources? stefan Pass Labs 12 20th August 2002 08:01 AM
Current sources (not sinks) dlharmon Pass Labs 1 6th February 2002 10:36 PM
Page generated in 0.10768 seconds (79.73% PHP - 20.27% MySQL) with 11 queries
