#291 | |
thanks a lot !!!
#292 |
With +-50V you Would get around 500W in 8 ohms, and few kW of heat so i wouldnt play with that high voltage.
With +-15V u get around 50W isnt that enough? |
#293 |
up4
Nelson himself uses 30-0-30 and 32 mosfet/chn (I think) for the XA200 and get 200W burning off 480W in the process, I would definitely stay below that. 15-0-15 gets you ~20 clean watts (clipping at ~30W). |
#294 |
Hi all,
where can i buy aleph x pcb`s? I live in europe... greets, Ralf |
#295 | |
I see ! thanks
I thought + - 50V DC only gives roughly 100WATT for poweramp... it seems SuperSymmetric is different... it doesn't waste much energy so according to HiFiZen's design (4 MOSFET output per channel), I can get 20 ~ 30 Watt output? or as skaara said, I can get 50W ??? cuz my speaker only has 89db Quote:
#296 |
up4 said: I thought + - 50V DC only gives roughly 100WATT for poweramp...
it seems SuperSymmetric is different... it doesn't waste much energy It is not more efficient, but it is a bridged amp, which requires lesser voltage rails for the same output power. |
#297 | |
no kidding !!!
now I see why 15VDC can boost up to 30W or MORE. please bear with my stupidness. Quote:
#298 | |
If you are familiar with distortion curves as a function of power, it should tell you that you can probaly listen to 20 decent watts during peaks of musical program. |
#299 |
Chad, I have received the board. Totally owesome.
Thanks alot for your time and effort. Yamin |
#300 |
Grataku:
What was output resistance during testing?
Jarek |
| wanted: Coral Beta 8 or Beta 10 full range speaker | francofil | Swap Meet | 2 | 28th April 2010 08:34 AM |
| Aleph-X Official PCB rev. Alpha | hifiZen | Pass Labs | 101 | 15th December 2002 10:21 AM |
| Page generated in 0.10500 seconds (73.59% PHP - 26.41% MySQL) with 11 queries |
