Old 23rd September 2009, 02:21 PM   #101
Default This is an ancient thread but an interesting take on water cooling.
There's a guy in England who water cools his computer and uses the ground outside his house as a heat sink. Apparently, at UK latitudes, ground temperature is around 8 deg C all year round at about 5 feet below the surface.
A high speed pump, some plumbing and you too can have a, for instance, tiny 4 inch x 4inch amp running class A, and not be heating up the house. On the other hand, if ground temperature is indeed that low, heating is just what you want.
Power supply would have to be external though. Hmm, maybe you could just build single driver active F amps instead with external power supply and water cooling...But what's the point?
Water Cooled Amp? MotoMan_Yz400 Chip Amps 19 5th March 2008 10:36 PM
Water-cooled Hojvaelde Pass Labs 24 24th May 2007 07:30 PM
hmm water cooled amp karma Everything Else 1 20th August 2003 11:43 PM
Water cooled plate on ebay (possible water cooled amp application) BrianGT Parts 1 27th May 2002 03:19 PM
Page generated in 0.06338 seconds (64.15% PHP - 35.85% MySQL) with 11 queries
