#291 |
Can the OTA be turned into a Power Follower ?
#292 |
It is a power follower
Mads K |
#293 | |
First, guys, forget about 4700uF output cap. Decent solution for an output cap, is three "caps" in parallel. 1-st cap: 33...68uF polyprop cap (closest to the schematics) 2-nd "cap": 16...20pcs of paralleled 1000uF Nichikon KZ (or Elna Silmic) 3-rd "cap": 1 or 2 paralleled 10000uF average quality caps in series with 50mOhms resistor (two 0,1R resistors in parallel). Whatever your impedance calculations say, adding of the 3-rd "cap" is listenable at bass domain. Next, NoNFB designs are very sensitive (from BASS point of view) to a kind of output transistors. Bass is getting better along this line: lateral MOSFETs, vertical MOSFETs, silicon BJTs, Ge BJTs. The laterals are "afraid" of current, while BJTs and especially Ge BJTs are "glad to accompany" the current. There is a ground to the fact, that Charles Hansen uses BJTs in Ayre amps. Even if Zout of designs with various kinds of transistors are close to each other, bass signature differs substantially. Deep NFB designs are also not free from effects of output transistors used. With lateral MOSFETs, even design with 60dB of NFB at 20kHz gives a bit weak bass. Vertical MOSFETs and BJTs are better for bass domain. PF99 is a great IDEA for SE output stage, but for extracting all potential from it, I have ended up with necessity of some pre stages and some so called "current NFB", with 300MHz BJTs at the output. This allows for great sound. |
#294 | |
My opinion is that one good quality 4.700uF cap is alright for 8 Ohm speaker. Are you sure you get better results with your way?
lineup |
#295 |
Hi Lineup,
Long time no talk. Capacitive decoupling (i.e. with capacitor) and direct coupling (i.e. without capacitor) perform different sound quality which is subject to individual taste of sound. If capacitor is used in input/output of circuitry, it must form an analog filter, common RC filter, or even LRC filter at output of power amplifier. (e.g. High pass, low pass, full pass, etc…) Becareful to use it as human audible frequency 20Hz-20KHz cannot be cut off. I can see many people repeat and repeat to misuse it, I have no time to comment anymore. Lastly, becareful to use capacitor!
"To work smarter, but not to work harder." by alant4321 http://www.teco-audio.com |
| Two Transistor Amplifier | Stinger | Pass Labs | 4 | 4th May 2009 12:29 PM |
| PCB's for Leach Amplifier 6 Transistor | Svetlana | Solid State | 3 | 19th September 2006 08:37 PM |
| transistor amplifier | anton | Car Audio | 2 | 12th July 2005 04:08 PM |
| Transistor Differential Amplifier | deesmygal | Parts | 0 | 11th November 2004 03:11 AM |
