OTA - One Transistor Amplifier - Page 3 - diyAudio
Old 8th February 2006, 03:20 PM   #21
Wisdom ? Why ? Try to tell to The God, that human body is " too complicated " and that he can make it more simply...He will thinking about it and result will be ameba...
Old 8th February 2006, 03:28 PM   #22
jan.didden's Avatar
Originally posted by thalis
Obviously, they are Wise.
So, it’s not called funny, dear Upupa, its called wisdom. Wisdom gives (always did and always will) simple and powerful answers to ‘complicated’ questions.
[snip]
Yes indeed. For every difficult, complicated and complex problem there is a simple, easy to understand wrong answer.
Jan Didden
Music is dither to the brain; lets me think below the usual chaos - me
Linear Audio Vol 13 is out! Check out my Autoranger and SilentSwitcher
Old 8th February 2006, 03:31 PM   #23
Yes, amen...
Old 8th February 2006, 04:12 PM   #24
Tube_Dude's Avatar
Hi Mad_K
Why do you do not use the minus rail as input ground?
The way you have , the input ground is referenced to the the positive rail and the source of the mosfet is referenced to the minus rail, but the voltage that the mosfet "see" and amplifies , is the voltage between gate and source...
With your grounding arrangement the PSRR will be very poor...
Jorge
Old 8th February 2006, 04:31 PM   #25
lohk is offline lohk  Europe
lohk's Avatar
Hi Mad_k,
isn't the output cap drawn reversed in your schematic? I should have plus to gound.
/lohk/
Old 8th February 2006, 05:40 PM   #26
Mad_K is offline Mad_K  Norway
Mad_K's Avatar
Originally posted by lohk
Hi Mad_k,
You're absolutely right, thanks. Attached is the corrected schematic.
Mads K
Old 8th February 2006, 06:00 PM   #27
Mad_K's Avatar
Originally posted by Tube_Dude
Hi Mad_K
source follower:
FET amplifier in which signal is applied between gate and drain with output taken between source and drain. Also called "common drain."
Mads K
Old 8th February 2006, 06:46 PM   #28
Tube_Dude's Avatar
Originally posted by Mad_K
source follower:
Do some home work, please:
http://www.eie.polyu.edu.hk/~ensurya...h2/Fig2-18.jpg
http://www.ee.bilkent.edu.tr/~aytur/.../labs/exp6.pdf
Jorge
Old 8th February 2006, 07:54 PM   #29
thalis is offline thalis  Greece
Dear Yan, this can also be true.
In Greek we have different words for ‘simple but probably effective’, and for ‘dangerously simplified’, but unfortunately the English translation is the same: ‘Simple’.
In my opinion many of these little circuits are simple and effective if someone has the right speaker: sensitive and of smooth impedance (which two quantities are regarded as speaker qualities, in my way of thinking, btw). Then they can prove to be sonically even better from more complicated, respected, and well measuring designs. As we all know, there are many people who have such experiences, and such simplicity can be considered as a certain ‘philosophy’ in sound reproduction. All these people have the right to experiment, listen, like what they listen, post their findings without having to deal with questions like “how can this play good music, so simple as it is, with such a distortion figure etc.?” again and again. In the same time and as I have seen, all these don’t get into other forum discussions (regarding more complicated designs) protesting or demonstrating their different point of view, saying for instance ‘why do you build such a 4 stage circuitry, why not cut 2 stages’, or ‘how can this work with so many parts?’.
In general, I presume that these people know better that Hi-Fi isn’t a one-way street, nor is it determined from specific specs, so I (again) presume they perhaps know better how to choose an appropriate way (since they don’t know of only one) to satisfy their needs.
Now, about simplicity and complication: Even for this simple matter, of someone’s right and pleasure to post here his findings and have a conversation (given his simplistic approach and likings) and get on-topic comments and disagreements like tube-dude’s and lohk’s, and nothing else, we people have to complicate things enough to loose our motives.
Old 8th February 2006, 08:12 PM   #30
Mad_K's Avatar
Yes, I'm well aware that's the normal way to connect it. I was thinking of the sentence I posted earlier, as this is the way it is descibed in my book "Microelectric Circuits". I would very much appreciate a lesson in how this affects the PSRR, and AC signal current loop, in the mean time I will redraw the schematic to comply with the normal way of thinking.
Mads K
Two Transistor Amplifier Stinger Pass Labs 15 30th January 2016 04:07 PM
PCB's for Leach Amplifier 6 Transistor Svetlana Solid State 3 19th September 2006 08:37 PM
transistor amplifier anton Car Audio 2 12th July 2005 04:08 PM
Transistor Differential Amplifier deesmygal Parts 0 11th November 2004 03:11 AM
Copyright ©1999-2017 diyAudio
