Connecting to the Aleph-X pcb. I have AC on the pwr supply. Is this ok? Also I have to much voltage on Q2 and Q11. Measured about 12V without turning on the variac to 220V.
#2 |
How much AC is on the rails? a few volts or a few millivolts?
Do you have the DC that you expect when the PSU is not connected to the amp? describe your psu - CRC? how much C and R? What is your expected rail voltage? What voltage do you get over R23 and R25? If less than ~4V you won't turn on Q2/Q11 and their drains will be close to the positve rail. |
#3 |
Several volts AC.
I have 18VDC as expected. I'm using this power supply: http://www.kk-pcb.com/power-x.html As I´m using this board http://www.kk-pcb.com/alephx.html I have to come back tomorrow for the voltage over R23 and R 25 |
#4 |
If you're getting that much AC then something is seriously wrong. Something is drawing a ton of current, you should be seeing millivolts with that filter. check for a solder bridge to ground or across the rails, backwards electrolytic or backwards FET.
The part numbering I was using refers to Grey's schematic. R23/25 are the 390R in the legs of teh LTP. |
| AC where it shouldn't be. | anders.a | Power Supplies | 34 | 14th February 2006 08:55 PM |
| The price issue: Why shouldn't I just get an integrated receiver? | Fryguy | Solid State | 1 | 8th August 2003 06:07 AM |
| Page generated in 0.06315 seconds (70.87% PHP - 29.13% MySQL) with 10 queries |
