Old 26th April 2008, 05:34 PM   #481
The one and only
Nelson Pass's Avatar
Originally posted by gl
I chose 26dB because 1) that's what Nelson used in the original XA series amplifiers, and 2) it's a common value in the industry and worked well in my system with my pre-amp. Note that Nelson now uses 30dB of gain in some current PL product because that's a new common value in HT applications.
My personal preference for amplifiers is low gain 20 dB or less. I think
it's very unfortunate that the customers have been convinced that
they somehow want more gain - all they get for their trouble is more
complex circuits and noise.
PS The 30 dB PL figure is an option - we ship 26 dB as a default.
Old 26th April 2008, 07:00 PM   #482
Default Jfet option in aleph x amp
I have been following this discussion since it first appeared by Graeme et al. What are the CURRENTLY available jfet options which will successfully work in this amplifier? To continue successfully in this hobby we need to take into account the financial resources and parts sources available to all of us.
If at all possible reference to an easily sourced item would be appreciated. The level of achievement on this particular endeavor to date is exceptional. Please continue on. Tad
Old 26th April 2008, 08:21 PM   #483
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Default Re: Jfet option in aleph x amp
as Grey mention numerous times - you can use J271
pretty easier to find , and cheap enough to buy them in quantities
buy , say , 100pcs of J271 and 100pcs of J310 , and you are safe for loong time
plenty for NN , NP, PP matching
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery
Old 26th April 2008, 08:27 PM   #484
EUVL is offline EUVL  Europe
The original has mosfet input diff pair -- IRF9610s. Widely available.
Patrick
Old 26th April 2008, 10:23 PM   #485
macka's Avatar
Thanks Nelson
Well 20 db is 10 x times.
That should be easy enough to measure.
I should have it installed later on this afternoon.
Ian
Old 27th April 2008, 12:07 PM   #486
macka's Avatar
Still working on the final assembly and the usual ritual of checking everything...3 times.
In case you are wondering the board would not fit anythere else!
Ian
Old 28th April 2008, 01:52 PM   #487
macka's Avatar
Here is one of the modules under test.
I have Graeme's feedback and input divider values installed.
I had a quick listen to it tonight. Some details tomorrow when I get the other channel up.
For the numbers people, offset at start up was 7 volts from cold and dropped quickly to a few hundred mv.
Relative Offset is about 30mv.
Ian
Old 29th April 2008, 11:08 AM   #488
macka's Avatar
I measured the actual voltage gain tonight.
These are the measurements;
Input voltage sine wave 100 hertz
34mv negative to ground
34 mv positive to ground
64 mv differental
Output voltage
640mv to negative to ground
640mv to positive to ground
1280 mv differential
That suggest to me 20 x gain
I am bit tired so perhaps someone can express that at db voltage gain.
Ian
Old 29th April 2008, 02:04 PM   #489
Halo Macka !
You can have this with relation Vdb=20log*Uout/Uin.
In your case is this 20log*(1280/64)=26.02 dB
Michael
Old 29th April 2008, 03:39 PM   #490
gl is offline gl  United States
Ian,
Excellent work there! And thank you for the pictures. Pictures are always encouraging. That said, I'll see what I can do about posting one or two here in the near future.
Tad, thank you for the feedback. Sometimes you wonder if anyone is interested in this thread other than the small number of people who post. On the other hand the number of views is getting pretty high and the thread does seem to stay on page 1 a lot of the time. Anyway, it's good to receive an encouraging word.
The 2SJ74 and 2SK170 are still available and probably will be for a few years.
Graeme
Page generated in 0.13123 seconds (75.79% PHP - 24.21% MySQL) with 11 queries
