Dear all,
I have posted few days ago a tread about some modifications. what I need to know, could I use 2,2mF/400V-MKP type to bypass zener diode Z5. Thank you, Regards, |
#2 | |
use 2u2/63V 400V one is a waste
my Papa is smarter than your Nelson ! tnx to thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
#3 |
2,2mF = 2200uF seems to be a bit big. Normally a 100-500nF should be enough. William
een ooievaar is geen konijn want zijn oren zijn te klein! |
#4 |
Chocky,
I have a 2,2uF/275v MKP, I can't find any other with lower voltage. So can I use them..... William, Sorry for bad typing. You suggest other value then many others??? Little bit confused....... Regards, |
#5 |
well since there is no current to speak of charging/discharging this cap and the main reason to put it there is noise reducting 2,2uF seems quite big (not only the value but also the size) That´s why I suggested 100-500nF. Probably you can go even lower. Nelson never bothered to put a cap here so maybe the input diff pair causes more noise than the zener........... Maybe someone made some measurements concerning the noise of the zener in the Aleph input current source? William
#6 |
Thank you William...
Regards, |
| First version Aleph 0 (Null, ZERO, O, Os, 0s) versus later Aleph versions | tiefbassuebertr | Pass Labs | 13 | 27th April 2012 02:13 AM |
| Aleph (Single Ended) + Larvadin (no Memory Distortion) = Ultimate Aleph? | tiefbassuebertr | Pass Labs | 17 | 9th January 2012 02:10 PM |
| Mini Aleph Board & Aleph 2 Parts List | gpsmithii | Pass Labs | 3 | 16th January 2010 03:58 AM |
| First version Aleph 0 (Null, ZERO, O, Os, 0s) versus later Aleph versions | tiefbassuebertr | Pass Labs | 0 | 6th August 2009 11:11 AM |
| PCBs for Aleph 2, Aleph 3, Aleph 4 and Aleph 5 amplifiers | kristijan-k | Swap Meet | 64 | 12th September 2002 07:55 AM |
| Page generated in 0.08855 seconds (77.42% PHP - 22.58% MySQL) with 10 queries |
