Will be finnished very soon........
Regards, Toni |
#2 |
You expect these heatsinks to handle the heat like this ?
Looks like Sponge Bob has killed another thread. |
#3 |
Why, you mean that they will not to be good enough...
Regards, |
#4 |
Each of the heatsinks will need to handle 75 watts if you are going for the nominal power output.
At 30 degrees temperature rise that translates to a thermal heatsink factor of 0.4 If you mount them like you did, with the flanges horizontal, the thermal factor will drastically reduce. They'll probably need to have a 0.2 thermal resistance to keep the temperature low enough. Based on the size of a Rifa capacitor your heatsinks look to be something like 8"x 16" My guess would be that your heatsinks will reach 70C at least. If you have the option to cut them in half, rotate the heatsinks 90 degrees and mount them side by side, they have a much better chance to handle that much heat.
#5 |
The size of the heat sinks are 18 x 12 inch. On each heat sinks will be mounted 3 fets. I think it would be enough. I know that orientation of sinks are not as should be, but I have to do that because of many factors. Thank's.....
Toni, |
#6 |
Good luck, please post the outcome.
#7 |
Thank you I will, I hope very soon. May I ask you something.... I'm using standard capcitors (those 220mF-YAGEO). Some where I've readed that I have to put 0.470mF across them, is that correct???
Regards, |
#8 |
Yes, bypassing an electrolytic that has the signal across it by a foil capacitor is always an improvement.
And you can also bypass the zener.
#9 |
It means that all capacitors should be bypassed, correct??? About zener diode, I assume that you mean for Z5...!!!!
Thank's |
#10 | |
| First version Aleph 0 (Null, ZERO, O, Os, 0s) versus later Aleph versions | tiefbassuebertr | Pass Labs | 13 | 27th April 2012 02:13 AM |
| Aleph (Single Ended) + Larvadin (no Memory Distortion) = Ultimate Aleph? | tiefbassuebertr | Pass Labs | 17 | 9th January 2012 02:10 PM |
| Mini Aleph Board & Aleph 2 Parts List | gpsmithii | Pass Labs | 3 | 16th January 2010 03:58 AM |
| First version Aleph 0 (Null, ZERO, O, Os, 0s) versus later Aleph versions | tiefbassuebertr | Pass Labs | 0 | 6th August 2009 11:11 AM |
| PCBs for Aleph 2, Aleph 3, Aleph 4 and Aleph 5 amplifiers | kristijan-k | Swap Meet | 64 | 12th September 2002 07:55 AM |
| Page generated in 0.09927 seconds (81.55% PHP - 18.45% MySQL) with 11 queries |
