Old 5th February 2006, 08:46 PM   #1
hifimaker's Avatar
Question Parallel transformer wiring for Aleph30???
I bought 2 Antek 2x22vac 400va transformers I'd like to use with BrianGT's mini-Aleph PSU board.
I've successfully hooked up the primaries and get 22vac at each of the secondaries.
My question: Is this the correct way to parallel these 2 400va transformers together for a single 22vac secondary with an 800va rating?
Thank you!
-David
Old 5th February 2006, 09:35 PM   #2
mpmarino's Avatar
I would just 'dual mono' it with 2 bridges and 2 sets of cap banks. It'll keep you out of trouble and a dual mono 400va each chan on an aleph at those voltages would be better than needed. IMHO those trafos are not EXACTLY matched and they won't play equally in parallel (load share) as you would like.....
regards...
edit: oh...but your schem does seem to be correct if you wanted to..
Crazy Yankee.
Old 5th February 2006, 10:16 PM   #3
tja is offline tja  Netherlands
Default Only one secondary?
What are you going to use for the other secondary?
Take
Old 6th February 2006, 03:31 AM   #4
hifimaker's Avatar
I was hoping to use a single powersupply with one bridge rectifier. Is this practical? The other option is to use 2 PSU boards, but given space limitations I was hoping to get away with only one.
Thank you,
-David
Old 6th February 2006, 04:23 AM   #5
You need both +22V and -22V. The scheme you cooked up above delivers just one of them. If you want to use one bridge parallel each transformers secondaries and use one transformer for the positive side and one for the negative.
In the attached picture break connections at the red crosses, join the green connection and attach it to ground
Be sure to verify this with someone who knows a heck of a lot more than I do.
Take
Old 6th February 2006, 01:31 PM   #6
mpmarino's Avatar
Take is right..your orig. schem is wrong. But I think you would want it as below. I would still go dual mono or at least use 2 bridges and parallel the dc after the bridges.....
Crazy Yankee.
Old 6th February 2006, 04:09 PM   #7
hifimaker's Avatar
mpmario and Take,
Thank you so much for your help!
I'm looking to get 22vac at the input of the rectifier. Would this design give 44vac or 22vac?
Thank you,
-David
Old 6th February 2006, 07:26 PM   #8
mpmarino's Avatar
44 vac total , or in other words, +-22vac referenced to the ground shown in my schem. If your building a traditional aleph 30 type amp you need about that voltage before rectification.
someone please flame me if i'm wrong so dw doesn't blow himself up.
Crazy Yankee.
Old 7th February 2006, 12:23 AM   #9
hifimaker's Avatar
I hooked it up as diagramed in post #1 and I'm getting +-15.6 volts after the rectifier. I was hoping to see 25vdc.
What's wrong here?
Thanks!
-David
Old 7th February 2006, 12:52 AM   #10
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
What's wrong here?
Thanks!
-David
you need caps after the bridge.
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
Wiring Power Transformer in Parallel kstylianos Tubes / Valves 5 7th June 2009 08:24 PM
Transformer wiring question, series, parallel and center tapped swin1 Power Supplies 12 7th November 2008 07:58 PM
parallel wiring 16 ohm 4 ohm tobler Subwoofers 3 21st November 2005 04:28 AM
I'm wiring my 4 channel 8 parallel LM4780 boards... check my wiring :) Audiophilenoob Chip Amps 9 16th August 2005 04:37 AM
Avel Lindberg 500VA 18-0-0-18 Transformer for Aleph30 BrianDonegan Group Buys 6 5th August 2005 02:40 PM
Page generated in 0.09685 seconds (84.41% PHP - 15.59% MySQL) with 11 queries
