I am building an Aleph X with about 300W of power consumption. I am using 4 X 47000uf on my PS. will that be enoguh?
Angus |
#2 |
It will work but as usual in Aleph amplifiers, more is better.
I used six of them in a CRCRC combination. R's are 0.1ohm. /Hugo |
#3 | |
What is the difference when i add the resistor between it? |
#4 |
From practice; you get a big reduction in ripple after every R and a small voltage drop. The smaller the resistor value, the smaller the voltage drop and the smaller the heat dissipation. When choosing bigger value resistors you start wasting too much power and need bigger resistors and heatsinks to cool them.
Not sure if a bigger value, say 0.5ohm has any effect on further decreasing ripple. Theory is for other people. /Hugo |
#5 |
Account Disabled
When R = 0.1 and C is 47,000uf,
Xc = 6.28 x 100 (50Hz) x 0.047 = 0.034 R+Xc = (0.1^2+0.034^2)^0.5 = 0.106 Ripple voltage attenuation = 20*log(0.034/0.106) = -10dB So, better supply voltage regulation . . . CRC = -10dB CRCRC = -20dB My calculation might be incorrect . . . anyhow, I am just trying to demonstrate how the ripple voltage could be reduced by the R . . . Regards jh |
#6 |
I´m using a CLC with 50000uF - 2.2mH - 100000uF per rail. This has even less ripple and doesn´t produce as much heat as resistors. I´ve used intertechnik torobars and tested them up to 10A without getting into saturation. William
een ooievaar is geen konijn want zijn oren zijn te klein! |
#7 | |
so less ripple current is better? |
#8 |
Ripple translates in hum, which is exactly what we don't want to hear.
/Hugo |
| Too much capacitance? | HaLo6 | Power Supplies | 24 | 14th June 2009 05:55 PM |
| Capacitance in PSU | kacernator | Tubes / Valves | 28 | 11th April 2008 06:21 AM |
| Aleph P1.7 output capacitance question | Adams_Leo | Pass Labs | 2 | 22nd August 2006 12:34 AM |
| Capacitance, anyone? | Jarno | Pass Labs | 22 | 17th February 2004 02:11 PM |
| capacitance 101 | Evaas | Solid State | 3 | 28th February 2003 08:02 PM |
| Page generated in 0.08751 seconds (74.82% PHP - 25.18% MySQL) with 10 queries |
