Problem with Aleph 2
Old 30th January 2006, 05:43 PM   #1
ppesa is offline ppesa  Croatia
Default Problem with Aleph 2
My name is Predrag Pesa and Aleph 2 is my 3-hird pass work.
After 50 hours work I have no words to describe the sound,
apsolutily magnificent. On the 57 celsius, with measuring on
PCB in the tolerance, this is wery well worked amp.
So where is the problem.
When I turn amp on , from one chenel comes allmost nothing,
BUT from another ,with gently"bumy" sound suck woofer in
2 or 3 mm, then hold there for 1 sec, then relesed in another
2 or 3 sec, after that everything is normal.
I used in power suply: 1KW toroid- trafo, 2 x 0,47microF MKT
40 A, 1000 V bridge
10 x 10 000 microF by Elna
I am not wery Good in electronic so simplier as you can please
By the way about bias and gain for Aleph 2, which elements
control them and where are they, thanks in advance
Greetings from Croatia.
Old 31st January 2006, 07:44 PM   #2
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
The Alephs have a small turn-on and turn-off thump, usually
around a volt or so, and that is typical. If there is no DC resistance
to the load to drain off DC, sometimes the cap in the feedback loop
will hold a slight charge, resulting in a turn-on thump larger than
usual if the amp has not been off for a while. Why one channel has
no apparent thump is probably just a coincidence of parts turning
on more synchronously than usual.
The gain of the amp itself is determined by the feedback loop. The
gain and bias of the current source is determined by the parts
surrounding the NPN transistor on the top half. You will find several
discussions on this forum detailing its operation.
Problem with Aleph 2Hide this!Advertise here!
problem with R44 on Aleph P 1.7 Stefanoo Pass Labs 15 9th October 2007 12:57 PM
Problem with aleph p 1.7 gabflo Pass Labs 7 2nd September 2006 05:50 PM
Aleph-5 Problem dzkh63 Pass Labs 0 14th September 2004 02:19 PM
Aleph 2 problem!Help... nar Pass Labs 14 1st June 2003 03:42 PM
Aleph 5 PSU problem please help? xsnailx Pass Labs 10 4th March 2003 06:28 PM
