What BIAS current is suitable for me? - Page 2 - diyAudio
Old 31st January 2006, 07:48 AM   #11
" To the left of the peak you are current limited - to raise power increase the bias. to the right of the peak you are voltage limited, increase rail voltage to increase power. " sorry my english isn't very good . can you explain this? i think the BIAS current is what i can set on the board using a variable resistor, as well as the rail voltage. any one have any suggestion of what rail voltage and BIAS current i go for?
Angus
Old 31st January 2006, 09:23 AM   #12
Dr.Gone is offline Dr.Gone  Netherlands
Angus
Did you take a look at the AXE-1.2 spreadsheet? There is a graph displaying the maximum power output for different impedances. There is a peak in the graph where the amplifier has its maximum power. At a lower impedance the amplifier is limited by the amount of current it can supply and with a higher impedance the amplifier is limited by the voltage at the fets.
I'm not sure if this post helps you but what i would do is this:
Take a look at the spreadsheet and fiddle with the numbers of
BIAS and 'voltage at fets'. Raising the 'voltage at fets' will move the peak output towards a higher impedance and raising the bias will move the peak towards a lower impedance (both resulting in more heat to be dissipated).
You can go as crazy as you like on the specs (although there is an upper and lower limmit), but remember you've got to get rid of the heat! And using 2 x 500 Watt class A amplifiers in your listening room will heat up the room considerably.
Jacco
Old 31st January 2006, 09:52 AM   #13
Jacco
I have looked at the spreadsheet, the problem i am having is where is the peak is the best? 8 ohm? 6 ohm? 12 ohm?
Old 31st January 2006, 10:07 AM   #14
wuffwaff's Avatar
5 ohm
een ooievaar is geen konijn want zijn oren zijn te klein!
Old 31st January 2006, 12:16 PM   #15
thank you very much.
why is it 5 ohm? is it the nature of Aleph or becasue of my speaker? what is the default BIAS current of a Aleph 2?
Old 31st January 2006, 03:55 PM   #16
wuffwaff's Avatar
the impedance of your speaker has a minimum of 5 Ohms so no need to have more power at lower impedances.
An Aleph2 is not an Aleph X and has a bias setting of around 3.3A
There is no default bias setting AND the voltage at the fets can only be changed by changing trafos!!!!! Not by changing resistors or fiddling with a pot!!!
William
Old 31st January 2006, 07:56 PM   #17
The one and only
Nelson Pass's Avatar
If quality of sound is the criterion, then the highest bias possible
is what you want. Often this is not practical....
Old 31st January 2006, 08:06 PM   #18
Wow, thank you Mr. Pass. So do you think about 50-60W output enough for me? People said the output from Aleph amplifier are very powerful Watts.
Old 31st January 2006, 08:19 PM   #19
The one and only
Yeah, that's the ticket.... 50 watts with 100 amp bias!
Old 1st February 2006, 07:12 AM   #20
i have now decided to use a 17V rail and 10Amp bias. will it be fine?
Angus
Would this make a suitable bias supply? bigwill Planars & Exotics 10 21st April 2007 04:26 PM
Suitable bias for 4 ohm subwoofer over 200W? EWorkshop1708 Solid State 12 21st January 2006 05:09 PM
Copyright 1999-2017 diyAudio
