What BIAS current is suitable for me?
Old 1st February 2006, 10:40 AM   #21
wuffwaff is offline wuffwaff  Netherlands
wuffwaff's Avatar
I think 10A of bias is a bit much for 17V and for your speakers. You will have 340 watts dissipation per channel and must use at least 12 Fets/channel. I you want thze dissipation it would probably be better to up the voltage a bit.
William
een ooievaar is geen konijn want zijn oren zijn te klein!
Old 1st February 2006, 01:17 PM   #22
lscangus is offline lscangus  United Kingdom
but from Mr Pass, higher current means better quality. and i think 60W will be enough for my proac
Old 1st February 2006, 05:24 PM   #23
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
Realistically, Alephs don't meet my needs until the rails get up
around 20 volts or more. For that power and current sources
at 50%, you are looking at a minimum of 4 amps bias total, which
comes out at 160 watts or so. If you are using 4 devices per
channel, the highest you might want to run it is maybe 5 amps,
which is 50 watts per device.
Old 1st February 2006, 05:45 PM   #24
so, will it be better if i use 21.7V and 8A?
Angus
Old 1st February 2006, 08:40 PM   #25
wuffwaff's Avatar
or 6A........
William
Old 1st February 2006, 09:29 PM   #26
Originally posted by wuffwaff
or 6A........
William
but why 6A is better than 8A?
Old 1st February 2006, 09:49 PM   #27
wuffwaff's Avatar
just trying to save you some money for heatsinks/ transformers/ fets etc.
You speakers are not really critical so 6A of bias should be fine.
If cost is no problem you can go for 8A bias but you have to consider that this will enlarge the problems you will encounter.
William
Old 2nd February 2006, 08:14 AM   #28
William
i am using two 0.26C/W heatsinks to mount total of 16 fets. with a 12X12 CM fan to increase air flow.. so i think it will be alright.
So.. finally.. 17V or 21.7V for the rail? as if i go for 17V, i can have higher current. but will it be powerful enough for my speakers?
Old 2nd February 2006, 10:35 AM   #29
wuffwaff's Avatar
Then go for the higher voltage.
Old 2nd February 2006, 11:04 AM   #30
thanks very much! i will have a thought and i will post the picture of my ampa dn the working process later.
What BIAS current is suitable for me?Hide this!Advertise here!
Would this make a suitable bias supply? bigwill Planars & Exotics 10 21st April 2007 05:26 PM
Suitable bias for 4 ohm subwoofer over 200W? EWorkshop1708 Solid State 12 21st January 2006 06:09 PM
Copyright ©1999-2017 diyAudio
