Old 5th February 2006, 06:45 PM   #61
promitheus's Avatar
Russ that looks great.
What would be perfect is a complete solution for preamp control.
Volume relay control and input mute relay control.
LCD or simple led display all controlled with one PIC Microcontroller.
A universal solution would be the best so you could use it with any kind of preamp.
Old 6th February 2006, 03:05 AM   #62
Russ White's Avatar
Send a message via Yahoo to Russ White
Thanks Man,
The idea is to make the project accessible to those with varying goals. Certainly our desire is to create a community driven project with features that meet our collective needs. That means it will be modular and I hope will have some appeal to those who want a simple basic knob based attenuator solution as well as to those of us who might like a more full featured remote and LCD type controller interface. I intend to make make this a key focus even in relation to our source selector project. The two will indeed meld together very well. All will be open to the public in terms of design and technology. Implimentation is left up to the user, but I will provide a lot to get people started including a nice functional controller. Nothting I have done here is new, I have not invented anything at all, and I intend to give full attribution to those I have learned from as they have done as well.
I just finished my attenuator caculator today it is much more than a simple spreadsheet, but it couldn't be much simpler to use. You just iput your desired resolution in db and the number of steps along with your desisred output impedance and the application spits out correct E96 (1%) resistror values for you, which if you run through SPICE will get you a true logaritmic (not anti-log) curve. You do not need to supply the resistor values at all, you are given them
Use whatever resistors you like, but we will likely supply Dales(RN60s) with our kits, but it is early in design yet and that has yet to be determined. I am not going to get into the "which resistor sounds better than what" debate as that is just nuts.
The PCBs are still a work in progress but coming along nicely. I have a basic prototype, but a more "final" version will lkely be done by the end of the week (real job schedule permitting) and based on that Brian and I will see what we can do.
Anyway, I think this type of attenuation fills a niche quite nicely, works like the best mechanical stepped attenuators (actually in many ways better) but with more resolution. I know it is exactly what I was looking for with my XBOSOZ. I think it is an ideal match. You could easily use it on input or on output as some like to do. Constant output impedance is much more critical than imput impedance, which is why this solution is much better than an ordinary pot. Output impedance can be as low as 1K while still maintaining high enough input impedance for most any source, and certainly input impedance can easily be adjusted.
Anway it is an extremely exciting project and I think the most significant addition to my audio chain yet.
Cheers!
Russ
Less pulp more juice Twisted Pear Audio.
Old 6th February 2006, 07:08 AM   #63
promitheus's Avatar
Then keep up the good work.
IT all sounds fantastic and cant wait to see more.
Old 6th February 2006, 07:47 AM   #64
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
Have you ever seen the little tine dale resistors I can post a pic of them on a board that i got off a guy on here ..? They are pretty small..
j'
Old 6th February 2006, 02:44 PM   #65
Magura is offline Magura  Denmark
Magura's Avatar
Originally posted by steenoe
What the heck, take a look at my friends
totally crazy volume control
http://www.briangt.com/gallery/magur...uator/pict0001 Can you spot the lighter in there
Steen
http://www.briangt.com/gallery/magura-40stepattenuator
This shows the project from a more informative angle
Magura
Everything is possible....to do the impossible just takes a little while longer.
www.class-a-labs.com
Old 6th February 2006, 03:20 PM   #66
promitheus's Avatar
I have seen that before, its absolutely crazy.
That would cost a fortune.
Old 6th February 2006, 04:30 PM   #67
DaveM is offline DaveM  United States
DaveM's Avatar
It would only cost a fortune if you have to pay for machining. When you own the tools, it mearly takes tons of time.
Old 6th February 2006, 07:48 PM   #68
analogair's Avatar
Magura
How many kilo's of Silver did you put into that spectacular piece of craftmanship ?
air is analog
Old 6th February 2006, 08:15 PM   #69
Banned
Probably about as much silver that is in this cable that im starting to sell and make
3 hours later and i have a pair of 4 foot cable's nice clean sound, Better than the cheap cables i have been using.
Old 7th February 2006, 07:04 AM   #70
Magura's Avatar
Originally posted by analogair
Magura
You are patly wrong Dave. The cost of the materials turned out pretty hefty as well. Just add the price of half a kilogram of silver, a couple of full ceramic bearings, etc.
Materials alone are at least 500 USD, most likely a lot more, I try not to do the math
Magura
BOSOZ input selector mjounot Pass Labs 3 24th December 2002 09:19 PM
BOSOZ input selector mjounot Pass Labs 0 22nd December 2002 08:51 PM
BOSOZ volume control ToB Pass Labs 7 23rd August 2002 06:39 PM
BOSOZ Selector/volume control wiring? SteveA Pass Labs 4 2nd March 2002 03:07 PM
BOSOZ Volume Control rothko Pass Labs 5 23rd January 2002 03:38 AM
Page generated in 0.11314 seconds (79.97% PHP - 20.03% MySQL) with 11 queries
