Old 29th January 2006, 08:11 AM   #1
quyda is offline quyda  Viet Nam
Default I need calculation formula for Aleph
Hi guys,
I'm kinda newbie here, and I'm planning to build a 30W/ch Aleph.
A have looked at the schematic from http://www.kk-pcb.com/
To my understand, The Aleph share the same topology and the different if Voltage per Rail, and Bias Current.
But I dont know how to
1. Calculate Bias current from Schematic
2. Does number of Mosfet matter? If I use IRFP250 (=2xIRF240) can I use more IRFP250 share the heat disspation per fet?
3. How Voltage/Bias Current affect DC offset?
4. Can I Built Aleph 5 and reduce Bias Current 30W/Ch
Any comment/suggest would be highly welcome
Cheers
Quyda
Ps. My Speakers are Yamaha NS-200M 6Ohm, 100W, 90dB.
Old 29th January 2006, 09:09 AM   #2
wuffwaff's Avatar
1. you can calculate the max. bias assuming that 0,5-0,6 volts is over the source resistors. Then I = V/R times the amount of fets.
2. not really, as long as the dissipation per fet is not too high
3. not
4. yes you could but then you could also build an Aleph 3 or 30 wich has a lower rail voltage (25 instead of 34 volts)
William
een ooievaar is geen konijn want zijn oren zijn te klein!
Old 29th January 2006, 09:39 AM   #3
Sorry for my ignorance but can you give me an easy example on a few Aleph. And if I want to tweak my Amp a bit, which component so I look?
If I build a Aleph 3 using IRF250, can I still use 4 Mosfet just like IRF244 or should I use 2 as Mr Pass said?
Cheers
Quyda
NEW Aleph-X calculation sheet: AXE-1 wuffwaff Pass Labs 60 21st October 2005 06:22 AM
Calculation formula help request; 20 gain is equivalent to how many decibles??? Darren Nemeth Chip Amps 2 26th February 2005 09:07 AM
Need help on x-over formula Jay Multi-Way 3 12th August 2003 05:28 PM
Anyone have the formula for... Rino odorico Multi-Way 4 22nd January 2003 04:07 PM
Page generated in 0.06988 seconds (70.36% PHP - 29.64% MySQL) with 10 queries
