[BOSOZ] PCB fot the Audio input Selection board
Old 31st October 2002, 12:35 PM   #1
PsykoK is offline PsykoK  France
Send a message via ICQ to PsykoK Send a message via AIM to PsykoK
Default [BOSOZ] PCB fot the Audio input Selection board
I plan to build a BOSOZ and this case I choose to use the Audio Input Selection Board from Seungyun Lee.
You can see some pics from his job here:
http://www.passdiy.com/gallery/zenpre-p1.htm
or here for the full project ( attention the site is in Korean):
www.diymania.net
The problem was that for this board, he has made the PCB layer by hand and the scanned pics are not in a sufficient quality to make some good PCB:
Top:
Bottom
My board design is not new, is the same as the original one. The board was designed with EAGLE and looks like that:
In the attached file you find all EAGLE files and a copy in Gerber format!
The part list and the wire plan are available here:
part list
wire plan
Alex
Old 31st October 2002, 12:44 PM   #2
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
[BOSOZ] PCB fot the Audio input Selection board Send a message via AIM to Peter Daniel
If you are really serious about your design, you might go one step further and mount relays directly to RCA jacks, still using PCB. Something like that:
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 31st October 2002, 01:03 PM   #3
zeno is offline zeno  Europe
What kind of relays did you use, Peter ?
Any surrounding logic?
Marc
Old 31st October 2002, 01:15 PM   #4
I think those are Swiss Altel. I bought them years ago surplus. No logic, just hardwired switching.
www.audiosector.com
Old 31st October 2002, 01:17 PM   #5
nothing fancy about these relays. Goldplated, inert gas etc ?
Do they harm the sound quality ?
Old 31st October 2002, 01:22 PM   #6
Yes it's an other good idea and it's maybe easier to build, thanks !
Old 31st October 2002, 01:23 PM   #7
I saw them in FM Accoustics equipment so I thought they must be pretty good. Of course, it was 8 years ago. These days I would do extensive testing regarding sonic signature, but, I didn't bother then.
www.audiosector.com
Old 31st October 2002, 01:24 PM   #8
Marc
You can found some good relay by www.schuro.de for an interesting price:
http://www.schuro.de/preisl-relais.htm
Old 31st October 2002, 01:31 PM   #9
So here is the rest. The active part is potted and mounted directly behind the relays. Beside the active module, there is another module with 10 relays, which swtch the feedback resistors, changing the gain from 10dB to 20 dB.
www.audiosector.com
Old 31st October 2002, 01:34 PM   #10
More:
www.audiosector.com
[BOSOZ] PCB fot the Audio input Selection boardHide this!Advertise here!
WTB: 1 BOSOZ and PS board faiyaza Swap Meet 4 6th December 2010 04:42 AM
Digital Input Selection Board OliverD Swap Meet 3 5th October 2007 01:10 PM
Poll! What do you use in your X-BOSOZ or BOSOZ for Volume Control and Input Selector? promitheus Pass Labs 87 19th February 2006 03:15 PM
Best BOSOZ preamp parts selection thoughts hifimaker Pass Labs 94 23rd March 2005 06:47 PM
Input Selection Relay Board Elkaid Parts 0 10th April 2003 09:23 PM
