#11 |
You can take a project apart at lightning speed...
#12 |
I decided to update it recently with Aleph P 1.7 circuits, so I made some pics in a process. Still waiting for its turn though.
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#13 |
Alex,
Thanks for sharing this. Wallace |
#14 |
Alex:
I downloaded your zip file, but my light EAGLE software can not open the board file. It is saying the file may be damaged! I tried it with 2 machines and they are all the same! Can you verify if the file in zip is good? Thanks Thomas |
#15 |
You should use Eagle 4.03
This should do the trick, No problems opening the file's. I also had problems opening the files, but after searching the internet finaly found the program. Be aware off a lot of cracks wicht you are directed to. Nils |
#16 |
I have made a BOSOZ input relay Board, pictured below. It uses 4 Quad NAIS latching relays each which switches the pos and neg inputs for a single channel. This is my 1st DIY in about 15 years so I am new at it, but this appears to work, my preamp will be ready in a month or two.
Its 2"x4" which is really small and there is kind of a wacky layout. Don't hate me! The layout is the best I could do since I am using the free eagle pcb program which limits board size. This is actually pretty good from a signal perspective (I think, hey this is my 2nd Board so what do I know), and is 2 Oz copper. All unselected inputs are grounded through 100K resistors. The diodes are there to protect reverse emf from hurting the relay contacts, as suggested by an app note I read once. Inputs are selected with a 9 pin contact. 1. set input 1 2. reset input 1 3. set input 2 4. reset input 2 5. set input 3 6. ground 7. reset input 3 8. set input 4 9. reset input 4. When I make a selection of an input through a momentary pushbutton switch, a diode matrix (on another board) fowards the appropriate 5 volts to the pins of this board and this board sets the relay you want and resets the 3 other relays. Its kind of foolproof (hopefully) but be forewarned, these relays are expensive. Oh, and do you see my cool 9 pin mini-DIN connector! (actually its not installed on this board...yet, but you see it in the layout) Yeah baby! I told you I was new at this. Wait till you see my BOSOZ. I am definately dangerous. Here is a combo-pic of the relay board.
#17 |
How much are you guys willing to spend the money for a relay (DIL relays) ?
I recently open the RS components catalogs on relay, and there are some (small current, DIL) relays costing about US$11 ! Also, what characteristics are good for audio purpose? I've seen some relays with various contact material: - Ag on Au (silver on gold) - AgNi + Au plated - 92/8 gold/silver alloy over silver-palladium contacts - Ag + Au clad - AgCdO (silver cadmium oxide) - etc. What are the best contact material?
The Great Saiyaman Siapa bertelinga hendaklah ia mendengar... (Mat 13:9) |
#18 |
| WTB: 1 BOSOZ and PS board | faiyaza | Swap Meet | 4 | 6th December 2010 05:42 AM |
| Digital Input Selection Board | OliverD | Swap Meet | 3 | 5th October 2007 02:10 PM |
| Poll! What do you use in your X-BOSOZ or BOSOZ for Volume Control and Input Selector? | promitheus | Pass Labs | 87 | 19th February 2006 04:15 PM |
| Best BOSOZ preamp parts selection thoughts | hifimaker | Pass Labs | 94 | 23rd March 2005 07:47 PM |
| Input Selection Relay Board | Elkaid | Parts | 0 | 10th April 2003 10:23 PM |
| Page generated in 0.10617 seconds (77.84% PHP - 22.16% MySQL) with 11 queries |
