Here is a modification to update the BOSOZ.
Please note that there is no need of output capacitors. Any comment will be appreciated. |
#2 |
Hi Peter
It looks pretty much Nelsons patent. I think You need some inputresistors, or you have to trust the outputimpedance of signalsource. May be the value of R8 is too high, try to short it, and add some more feedback. Could You explain some more of Your point of views on this one. I would like to do some sims, but it will be in the evening. Could be an interting project.
Henrik |
#3 |
If You take away the folded cascodes, You end up with a simple XBOSOZ or a XSOZ for that matter.
As I remember, Nelson once talked about these folded casodes, and I thik his reason to implant these was to acheve better linearity at frequences higer than the audioband, >100kHz. So do we need them at all?
Henrik |
#4 | |
Erik |
#5 |
With the folded cascode the differential pair sees a constant voltage then the bandwith become better and the distorsion low.
Not to mention the output swing. Sure it helps drive such difficult loads like some x-son of zen back in the x-soz thread. Cheers |
#6 |
I would agree the second cascoded stage is not so important for small signal, audio frequency and low gain application. In this circuit, I intended to level shift the output signal to eliminate the potential dc voltage to a quite low value. This can be done by adjusting the potentiometers VR1 and VR2 in the circuit. Thus, the output capacitor shown in the original bosoz project can be kicked away. I don't like signal capacitors.
In this circuit, the original bosoz parts is still remained in and only two p mosfet and three 750 Ohm resistors are added. It would be quit easy to modify the original bosoz, if you had constructed one. I constructed a bosoz without pcb and preserve some space to upgrade. I don't like feedback either. I would take out the resistors, R4 and R10. I hope somebody can help to analyze performances of this circuit. Thanks. |
#7 |
When I played around with this circuit , some months ago, I did notice that it didn't work if R10 and R4 were out.
...but I may be wrong. |
#8 |
Here are my simulations.
#9 |
Another drawing
#10 |
Interesting , Peter .
What do you think to drive it balanced? |
| To BOSOZ or not to BOSOZ... please comment. | spence | Pass Labs | 4 | 27th February 2012 02:57 AM |
| Poll! What do you use in your X-BOSOZ or BOSOZ for Volume Control and Input Selector? | promitheus | Pass Labs | 87 | 19th February 2006 03:15 PM |
| X-bosoz vs. CCS X-bosoz, how does the sound compare? | acliao | Pass Labs | 14 | 26th February 2004 12:55 AM |
| Bosoz | lawbadman | Pass Labs | 5 | 14th July 2003 02:10 AM |
| 10K Pot for the BOSOZ | raincheck | Pass Labs | 13 | 20th September 2002 06:22 PM |
| Page generated in 0.10766 seconds (75.78% PHP - 24.22% MySQL) with 11 queries |
