Old 30th October 2002, 11:48 PM   #1
Holger Barske's Avatar
Default New aleph pcb design
Hi!
Recently made the decision to join the “Aleph club”. Although there is some very interesting pcb artwork out there, I couldn’t resist to try an own approach. This is where it ended up until now.
The board is meant to be an Aleph 5 (3 FETs paralleled, but the design can very easily be scaled for other Aleph models.
The board measures 100 x 81 millimeters (4 by 3.2 inches) and seems to be the most compact solution so far. It is, as usual, a single layer layout and I am a little proud to say that I succeeded completely without addditional wiring.
The amplifier output stage is located on the left, the current source power stage on the right side. I tried to keep the signal path as short as possible, there are for example only 54 millimeters from the speaker output terminal to the inverting input gate of the differential pair.
The diff pair may be thermally coupled, I placed the FETs back to back..
All power resistors will be Isaplan metal foil types, I’ve had some good expereiences with those. If it turns aout to be necessary, they can be mounted on a heatsink – a strip of aluminum may be sufficient.
As you can see from the artwork, I separated high from low current traces on both supply rails and the output wherever possible.
By now, the component numbering doesn’t match the standard from the aleph manual, I will change that in the future.
At the moment, all this is nothing but pure theory, and I am convinced there are a lot of errors on that design I don’t recognize at the moment, perhaps you do? Tell me what you think!
Schematics:
Best regards: Holger
www.holgerbarske.com
Old 30th October 2002, 11:50 PM   #2
Component layout and names:
Old 30th October 2002, 11:51 PM   #3
Component values and artwork:
Old 30th October 2002, 11:53 PM   #4
Artwork only:
Old 31st October 2002, 12:09 AM   #5
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
can you send me that art work smaller in tiff or jpegs please..
jleaman@citytel.net
thanks..
Old 31st October 2002, 12:16 AM   #6
On it's way...
Old 31st October 2002, 12:39 AM   #7
Can you please send me a copy of the art work on a smaller size
at nbaula@concentric.net . Thank you
Old 31st October 2002, 12:58 AM   #8
Changed the pics for smaller ones. HTH.
Old 31st October 2002, 01:39 AM   #9
Can you please send me a copy of the art work at "longlife@ms1.url.com.tw" Thank you
Old 31st October 2002, 01:53 AM   #10
Banned
i didnt get a copy
here are my main email addresses
jleaman@citytel.net
jleaman@kaien.net
Aleph PSU design thoughts Buhl Pass Labs 3 13th January 2009 03:09 PM
Aleph X Power Supply Design. Needs Help lscangus Pass Labs 11 1st May 2006 10:57 AM
Aleph 2 Board Design JayV Pass Labs 46 16th August 2003 04:46 PM
Preamp design (Aleph P 1.7) Karlos Pass Labs 3 5th August 2002 10:40 AM
Best Pass Design Zen, SOZ, Aleph 30?? mozfet Pass Labs 15 29th July 2002 01:06 PM
Page generated in 0.09120 seconds (79.42% PHP - 20.58% MySQL) with 10 queries
