Yet another softstart PCB
Old 20th January 2006, 02:46 PM   #1
harryeng is offline harryeng  Netherlands
Talking Yet another softstart PCB
Hi Group,
This is my own softstart PCB design. Yes, I know, there are lots of others in the forum. But I am particularly proud of this one, because itís mine. I presented it inside another thread, and got a lot of questions about it, so I decided to give it itís own thread.
The softstart is designed specifically for Pass amps. You can use it to start up the amp with both an external signal, and with a switch.
I wanted to minimize both loose parts, and 230 cabling inside my amp. So I integrated the fuse on the board. The incoming power cable is connected directly to the board, and the on-off switch is integrated in the control circuit. I also integrated the bi-metal protections into the control circuit, which results in a minimum number of switches (and cables) in the 230 VAC circuit.
Itís small: 5.5cm x 10 cm. I use it inside my Aleph 5, but it can switch up to 12 amps. Start-up is done with four resistors in series, and after the chosen start-up time a second relays short-circuits these resistors leaving just one relay contact in the power path.
The development took a long time, as this was my first PCB and I had to bone up on a lot of knowledge. The first designs had way too many options, so I ďPassedĒ it, and threw everything out that did not really attributed to the start-up function. The only option I left, were three connection points that can be used for powering a DC protection circuit. The selected transformer can supply power for four relays
I know a question that is coming, but I do not have enough PCBís left. As this was a sort of try-out for me, I only ordered a small set with 10 boards. Those left are spoken for, by Berry and Leeuwarden.
Greetings, Harry
Old 20th January 2006, 02:51 PM   #2
Default Schematics
This is the schematic belonging with the PCB.
All the parts (without the PCB) are only 20 Euro's
Old 20th January 2006, 02:57 PM   #3
Default Eagle
This is the PCB
Harry
Old 20th January 2006, 02:58 PM   #4
And here is the BOM, and the original Eagle files
Have fun!
Harry
Old 23rd January 2006, 01:39 PM   #5
promitheus is offline promitheus  Europe
promitheus's Avatar
that looks cool.
How do you use that DC control.
Old 24th January 2006, 08:25 PM   #6
Berry is offline Berry  Netherlands
There is no dc protection in the circuit, you can use a dc protection with this board. The External DC in is an output from a pre-amp that turns the amp on.
Yet another softstart PCBHide this!Advertise here!
Looking for a softstart kit... rtate Solid State 7 28th February 2008 03:09 AM
When to use softstart lordvader Power Supplies 27 29th November 2007 10:41 AM
Softstart for Zv9? sts9fan Pass Labs 7 8th November 2006 01:33 PM
Copyright ©1999-2017 diyAudio
