Hi there !
Everybody should check the new Aleph 4 project thatīs posted in the Passlabs site. It looks cool and a very good job. Soon pcbīs. A lot of thanks to Mark Finnis who posted his amp. |
#2 |
gee you were quick!
100 Watts @ 8 Ohms of single ended pure class A! This beast was worth a fortune. On the site the builder says he will forward the .pdf files of the PCB to "desmond". Is this a kit re-seller? Thanks for the heads-up. BTW the site is here: http://www.passlabs.com/gallery/a4-p1.htm |
#4 |
Hi Folks,
FYI. Desmond Harrington is the webmaster and PR person for PassLabs. If you want any info from PL he should be your first port of call rather than NP himself. Being the said builder of the Aleph4 a little info. I am not a reseller. Anyone is welcome to any info re the amp. You can get a PDF from the projects gallery which has the necessary info: http://www.passlabs.com/images/gallery/a4-p1-pcbs.pdf You can use IFRP244, IFRP240, IRF244 ..... NP states it doesn't matter. IFRP240s are what he would (and does) use now. NOTE: there was an ERROR in the first PDF which omitted a join from C9-R26 to the base of Q3. I have sent Des a replacement file which should be on the site as we speak. |
#5 |
The Irfp 240 I think are the easiest to find.
The only problem is they need matching which is easy to do with 1 resistor and a good digital multimeter. The only problem is that they cost more the input ones. Itīs just something you have to do if you want your amp to be perfect. Thatīs the whole idea anyway. |
#6 |
Really thanks to Mark Finnis and excellent job on the Aleph 4. I am about half way though my A40 and want to put it on the back burner and start an Aleph.
#7 |
Yeah it looks great !
I am still trying decide what to do ? The thing that troubles me the most is the box. But its a big help to have ready pcbs. |
#8 |
100 W class A Yees please!
I was triing to get the schematics. But could not folow the tread. Could you post them please. PS I have started to work on the heat sinks Plan is to use 2mm copper sheet and 4 mm thick buss bar + fans for which is quite easy to make a speed controler (speed increse with temperature ) So far cost is around Ģ30 for the copper (I have same good sources) Copper is a beter conductor than alluminium it does oxidise with time but it can be Gold Silver or Crome plated again I shuld be able to get this cheap. I will let you know but I am stuck witout the schematics. |
#9 |
This is an OLLD thread ...
Easiest to get at from my own page: http://www.users.on.net/~mefinnis/passlabs/aleph4.htm Cheers Mark |
#10 |
The links to the PassLabs site doesn't work on my PC.
How can I see the pictures? |
| Pass Labs BZLS and Aleph 2 Clone project for sale | qwertyl | Swap Meet | 0 | 9th September 2008 03:11 PM |
| First Pass project, need Aleph-M PSU advice please | ssmith | Pass Labs | 14 | 12th June 2007 10:25 AM |
| Pass Tharagard A75 vs Pass Aleph 1.2's | daly41k | Pass Labs | 7 | 18th February 2007 03:10 PM |
| pass aleph P VS pass X2 first version | perusicchio | Pass Labs | 10 | 5th March 2004 10:06 AM |
| Pass aleph 3 project | promitheus | Pass Labs | 90 | 9th August 2001 07:58 AM |
