Old 31st October 2002, 02:04 PM   #31
UrSv is offline UrSv  Sweden
UrSv's Avatar
Recommendation according to the article on ZenV4 which gives you the information in writing from Mr Pass himself:
2*18 VAC giving 36 VAC at 300 VA per channel.
If running one transformer for both channels 500 VA would be suitable.
/UrSv
Old 31st October 2002, 03:11 PM   #32
wchick is offline wchick  United States
herm,
I'm glad to hear that your heatsink work out so good. Seem quite likely that my coming A5 should be cool enough. By the way, did you buy your heatsink directly from Aavid? If so, did you buy a big piece and cut by yourself or buy them pre-cut? Also, I'm very interested to know how much they cost you.
UrSv,
I noticed that you diy yourself a pair of ProAc 2.5 clone. I wonder what amp you feed them. I plan to build a pair too and feed with pass amp (most likely Aleph 5). I know ProAc sound great with tube. Could you give some comment about this? Thanks.
Wallace
Old 31st October 2002, 03:14 PM   #33
UrSv's Avatar
The ProAcs are currently driven by a DENON AVR-2800 but that will be replaced by an Aleph 30 as soon as possible.
BTW. The ProAcs do not sound bad at all with the Denon...
/UrSv
Old 31st October 2002, 03:43 PM   #34
herm is offline herm  United States
Wchick;
I paid $50 for (2) 18" sections.
I got them surplus from a local motor control manufacturer
through an inside source. Too bad I can't get more - I
would buy every one they had!
I had a buddy cut them with a band saw into 9" lengths.
Not too hard, but use lots of lubricant.
-herm
Old 5th November 2002, 11:13 PM   #35
Question re: transformers. wchick, you have located your toroids side by side. Is there any bad effect from locating them stacked on top of one another. Like, some kind of saturation effect or magnetic interaction between the two?? If not, sure would save horizontal real estate to do so.
{P.S. - That is a very clean looking amp you have there, wchick. Heat sinking looks more than adequate. Hope my intended ZenV4 sinks will work --couple of 23 year old Heathkit sinks that would have been on the side of their 250 wpc kit super amp (I bought them as parts).-- but they have no where near the surface area that yours do. Have used Elliot's calculator to est. thermal resist. but not sure}
Larry Wright
Seattle area
Old 6th November 2002, 04:31 AM   #36
Larry,
I can't comment the issue about stacking transformer. I myself tried to avoid this, that's why I placed them side by side. However, I do see quite a number of fellow diyers stack their transformer. Maybe other experts may comment this.
Heatsink in my amp maybe sufficient but not efficient because they are in 3 separate pieces. One of them is significantly hotter than the others. I hope you have single big heatsink in your case.
Wallace
Old 11th November 2002, 03:36 PM   #37
wchick;
As I stated before, I am running the Zen4 in low
power mode ( no R1 ). I am dissipating approximately
66 watts in to each 9 inch sink.
Using a kitchen thermometer, I measure a temp
of 112 degrees over a 62 ambient (fahrenheit).
Looks like you will be in good shape with your
aleph 5 monos.
-herm
Old 11th November 2002, 09:54 PM   #38
Thanks for your info, Herm. Really appreciate.
Wallace
p3a dual mono? Big gain Solid State 19 15th November 2006 10:14 AM
making dual mono jack from single mono jack dubmunkey Analog Line Level 2 12th October 2006 02:16 PM
Why dual mono? preiter Chip Amps 11 21st September 2006 09:37 PM
Single Mono's or Dual Mono? Tazzy Pass Labs 8 3rd October 2002 02:03 PM
Dual Mono - Anti Mono Power Supplies pmkap Everything Else 3 16th February 2002 05:10 AM
Page generated in 0.09807 seconds (80.53% PHP - 19.47% MySQL) with 11 queries
