Old 13th January 2006, 07:13 PM   #1
Default Trouble with my Aleph-X
I’m about to start my Aleph-X and having trouble. I’m using a light bulb for inrush current protection.
Without connecting to the board the power supply is ok. The light bulb starts glowing and slowly it’s getting weaker until it won’t glow anymore. But when connecting it to the PCB about halfway when slowly racing using a variac the light bulb won’t totally stop glowing. There’s a faint constant light that won’t go away.
I’m using Kristjans board.
Anyone knows what the problem is?
Old 13th January 2006, 07:33 PM   #2
Holger Barske's Avatar
Well, maybe it's a stupid idea, but:
When you connect the amplifier to the supply, it draws current, I suppose. So why shouldn't the bulb give some light when there's current flowing through it...?
Best regards: Holger
www.holgerbarske.com
Old 13th January 2006, 07:35 PM   #3
That would be a relief.
Old 13th January 2006, 07:49 PM   #4
Netlist is offline Netlist  Belgium
Netlist's Avatar
Default Re: Trouble with my Aleph-X
When powering up, the glow of the light bulb is actually the charging of the supply capacitors made visible. When no amp connected, the caps remain charged but have nothing to supply their current to. Hence the light stops glowing when the caps are fully charged.
/Hugo
Old 13th January 2006, 07:52 PM   #5
steenoe is offline steenoe  Denmark
steenoe's Avatar
If you want to get rid of that light bulb, I think I have a spare Thermistor I can send you Well, I see the purpose of the bulbs in the ZenLight, but as current inrush limiter.... well okay its maybe pretty cool, but ... Send me an email if you want it
Steen
Old 13th January 2006, 07:57 PM   #6
Netlist
Yes but shouldn’t the light slowly fade away? What happens now is that the glow slowly fading until there’s a faint constant glow.
steenoe
The light bulb is only temporally.
Old 13th January 2006, 08:01 PM   #7
steenoe's Avatar
Oh, that explains!! I was rushing into things as usual Sorry 'bout that
The offer stands, nonetheless
Steen
Old 13th January 2006, 08:18 PM   #8
Netlist's Avatar
Because this is a class A amplifier it constantly draws a huge amount of current. It is heavily biased, simply explained, it draws the maximum current that it can deliver at all time. Therefore the light bulb will always be able to burn, be it only a little bit. Try increasing the current draw of the amp, you should notice more glow.
/Hugo
Old 13th January 2006, 08:21 PM   #9
Thanks. I was afraid I did some stupid soldering mistake on the PCB. And now what’s the next step? To monitor the temperature (max 60C)? Measure voltage somewhere? Setting absolute and relative DC?
Old 13th January 2006, 08:29 PM   #10
Netlist's Avatar
What you described till now is normal behaviour. Which does not mean the amp is perfectly working. Now is time to do some DC measurements. I'm looking forward to see some picture and hear you rave about the sound.
/Hugo
Trouble with amp 6V6 Tachyon Tubes / Valves 12 13th October 2008 05:25 PM
amp trouble please help up2me Car Audio 12 24th January 2008 02:51 PM
Trouble in a new DIY amp. andRookie Tubes / Valves 33 7th May 2007 09:04 AM
Amp trouble... WackiCO Car Audio 6 30th January 2007 10:38 PM
PCBs for Aleph 2, Aleph 3, Aleph 4 and Aleph 5 amplifiers kristijan-k Swap Meet 64 12th September 2002 07:55 AM
Page generated in 0.09408 seconds (80.78% PHP - 19.22% MySQL) with 10 queries
