I have two 300 VA transformers with 35x35 secondaries that I was initially planning on using for the Low TIM Leach amp, since the Aleph 5 looked to be too hard to construct with my limited tool skills. However, now that I've completed training at one of my school's machine shops, I have free access to milling machines, lathes, drill presses, saws, grinders, and more, and the training to use them. So construction of an Aleph 5 doesn't look impossible anymore.
Since I already have the two transformers mentioned above, would they be sufficient each for one channel of the Aleph 5? The Aleph 5 uses much lower voltages (25x25, right?) - how would I go about lowering the 35x35 secondaries to 25x25, and if that can be done well, would there be enough power from the transformers to power one channel each? Thanks, Greg |
#2 |
I had a similar problem and i solved it with a lamp 220V 150W in series with the primary of the transformer. the voltage dropped to half. you get a lamp and an amp for the price of one
I think you can also unwind the transformer, but I dont know exactly how to do that. I think someone did that in the forum. try a search on "unwinding transformers".
Pedro Oliveira |
#3 |
I think you could do well by regulating the supplies to the Aleph 5 level (34 VDC I think). Try the Zen V4 article on regulation. You would get a drop of roughly 12-15 V in the regulator at 2 amps per rail per channel meaning that you would have another 50-60 W of heat giving you a total of some 200-220 W of heat to dissipate. If that is too much I suggest choosing some other amplifier as the transformers would be too small for an Aleph with higher rails.
/UrSv |
#4 |
The one and only
I like the lamp idea, but for 120V use I would recommend
120 Volts at 300 watt bulbs in series with the AC line, and parallel them until you get the secondary voltage you want. Because the Alephs have a constant average draw, this works out pretty well. Of course another fine alternative is a big fat inductor in series with the AC line. |
#5 | |
#6 |
Looks like this is going to be more trouble than I thought, having to deal with the extra heat and... light bulbs?
I'll just sell my transformers and buy the proper ones. ![]() Thanks for all the help though. |
#7 |
don't be so pessimist!
look at my amp with the lamp on hope that cheer you up
Pedro Oliveira |
| WTB: 2 transformers for mini-aleph | Tristanc1 | Swap Meet | 1 | 27th September 2007 03:44 AM |
| Aleph 1.2 transformers buzzing | daly2k | Pass Labs | 10 | 23rd August 2005 02:40 PM |
| Aleph X Toroidal Transformers for Sale | kilowattski | Swap Meet | 10 | 28th July 2005 02:26 AM |
| PCBs for Aleph 2, Aleph 3, Aleph 4 and Aleph 5 amplifiers | kristijan-k | Swap Meet | 64 | 12th September 2002 07:55 AM |
| Aleph 2 Transformers for Sale/Trade | harvardian | Swap Meet | 9 | 29th April 2002 07:51 PM |
| Page generated in 0.09027 seconds (81.19% PHP - 18.81% MySQL) with 11 queries |
