This is my first thread on this forum...
I’m on my way to build an Aleph 1.7. And I would like to have some comments on the PCB layout I’ve done, my first one ever. When drawing the prototype I prefer to do it with thin tracks, the final version will have broader ones. /loovet |
#2 |
I would split the psu and preamp.
#3 |
Nice work... but....
It seems like you have mixed something with the input and output signal.. Both input + / - are shorted with the ouput over R72 and R57.. The input signal also seems to be connected with C15,C16 and C14.. respective on the other phase.. I think you have placed the input at wrong place... it should be placed to R6 and R5 I think I would try to get som more space around the FET's. Easier to put some heatsinks on them. Input/Output GND is connected with R3.. ?? I'm also working on a Aleph 1.7... Drawing it for 2-layer PCB, not wery easy. >Per Olav |
#4 |
Thanks for the responds…
skaara: you are so right, to make the hole thing more flexible, I will separate the preamp and the PSU. audioPON: you are so right too - I have put the inputs at wrong places; the inputs should be at R5 and R6. - I have considered more space around the FET’s. But since I will use Mcap capacitors, and these are not that small, I find it difficult to get this space. Do you have any ideas? First I’ve hade a thought about make it a double side one. But since this is my first project I was recommended to not. - R3 symbolizes the pot that controls the gain of each channel. Are you going to have this pot or will you put a fixed resistor instead. And if so, which value will the resistor have? /loovet |
#5 |
I am not shure how much heat must be dissapated, maybe it is enoght with a alu. strip that is formed like an S og U...
I will keep the R3 pot. |
#6 |
any coments?
/loovet |
#7 |
Nice work loovet
I am working on a Aleph 1.7 here is my prototype |
#8 |
Nick, Looks nice, what type of coupling caps did you make room for there?
Mark |
#9 |
Nick, I think that you have done a nice work too.
How have you done the design, which program are you using? /loovet |
#10 |
Hi guys!
I using for test WinCircuit 2002 ist Limited version by http://alain.michel13.free.fr I have TL mkt 600V 2% Caps |
| First version Aleph 0 (Null, ZERO, O, Os, 0s) versus later Aleph versions | tiefbassuebertr | Pass Labs | 13 | 27th April 2012 02:13 AM |
| Aleph (Single Ended) + Larvadin (no Memory Distortion) = Ultimate Aleph? | tiefbassuebertr | Pass Labs | 17 | 9th January 2012 02:10 PM |
| Mini Aleph Board & Aleph 2 Parts List | gpsmithii | Pass Labs | 3 | 16th January 2010 03:58 AM |
| First version Aleph 0 (Null, ZERO, O, Os, 0s) versus later Aleph versions | tiefbassuebertr | Pass Labs | 0 | 6th August 2009 11:11 AM |
| PCBs for Aleph 2, Aleph 3, Aleph 4 and Aleph 5 amplifiers | kristijan-k | Swap Meet | 64 | 12th September 2002 07:55 AM |
| Page generated in 0.09576 seconds (77.05% PHP - 22.95% MySQL) with 11 queries |
