Old 30th December 2005, 05:25 PM   #1
jeapel is offline jeapel  Canada
Default digi-key resistor ???
hi
With a parts list took on internet i order my aleph
resistor 1/2 watt 1%
exemple : PPC10.0KXCT-ND
but the resistors look very very small like 1/8 watt
is it normal or i must order other ?? or somebody with
same experience like me
thanks
Old 30th December 2005, 06:22 PM   #2
Blues is offline Blues  United States
Lightning In A Bottle
Blues's Avatar
Your example is a Phoenix resistor part#. I don't see a 1/2W value from the Phoenix list but if you're ordering for example a 1W/1.0k/1% it would be: PPC1D1.0kCT-ND and its body is about 10mm long and 4.3mm in diameter.
Old 30th December 2005, 08:18 PM   #3
on digi-key i read 1/2 watt but just 3.4 mm long ??
Old 30th December 2005, 08:26 PM   #4
with my lens :-) it s just 3mm long 1/2 watt tag on digikey
but i don t beleive it
Old 31st December 2005, 02:06 PM   #5
BrianDonegan's Avatar
Believe it. They are Phoenix mini resistors. Panasonic also make some mini resistors in 1/8 and 1/4w size (also available from digikey).
Datasheet for Phoenix
Twisted Pear Audio
Old 31st December 2005, 05:27 PM   #6
hi Brian thanks for the datasheet
smaller with bigger watt it s new for me maybe these resistors
are very heat resist but become very hot also or it s a new
version of thermodynamic law :-)
for aleph 3 i m right with all 1/2 watt except .47ohm 3 watt
or some resistor need more and have you pratical
experience with mini resistor
Old 31st December 2005, 06:44 PM   #7
They will certainly get hot if you pass the rated power though them.
Here's a pic of my Aleph30 board using Peter Daniel's boards. I used Panasonic mini 1/4W resistors and Panasonic 3W for the output.
Twisted Pear Audio
Old 31st December 2005, 08:26 PM   #8
thanks for help Brian but if possible have you
a part number example for your aleph 30 panasonic mini resistor
maybe mouser or digi-key
Old 31st December 2005, 08:39 PM   #9
I can do you one better.
Here is a downloadable spreadsheet for all the parts from DIYAmps.com (BrianGT's non-chipamp site).
Note that the part numbers (R1, R2 etc) do not directly corrispond to the NP schematic parts, but you can do the mapping. It has the Digikey part numbers for everything.
Twisted Pear Audio
Old 1st January 2006, 02:00 AM   #10
good new my mini resistors are not so wrong after all
happy new year in diy hobby :-)
Digi's GC not working. Evilsizer Chip Amps 15 2nd December 2005 06:08 AM
DIGI 125 - right VAS selection Greg Erskine Solid State 15 15th July 2004 10:05 PM
where is modified DIGI-125? palesha Solid State 4 3rd June 2004 04:48 AM
Digi 125 tomcat Solid State 0 15th May 2002 10:52 PM
Page generated in 0.10721 seconds (81.85% PHP - 18.15% MySQL) with 11 queries
