Old 24th October 2002, 04:28 PM   #1
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
Default Input impedance of Aleph X
Since I'm very close to finishing an Aleph X, I got an occasional question as I go. This one is about input ground resistors.
Both Grey and rtirion used resistor's values of 68k and 100k respectively. Reading Balanced BOZ article one might learn that the input capacitance of the MOSFETs puts a natural upper limit on that value and for best performance values exceeding 25kohms are not recommended. Is it a case here too?
All the other Alephs ground resistors don't exceed 10kohm values. And what about the feedback resistor? What effect does changing from 100k to 200k brings, if any?
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 24th October 2002, 07:58 PM   #2
The one and only
Nelson Pass's Avatar
The resistive value experiences is essentially the parallel
values of feedback, input+source, and ground resistors.
Resistors to ground are best implemented at the input
itself, so that all three resistors attach to the input node,
and this means that the load experienced by the circuit
driving the amp's input is the input resistance alone.
25K is close to the natural limit for the input resistor, but
this depends on the input capacitace of the devices and also
the gain. If you want to give up something else, you can
go to very high impedances using small Mosfets or even
Jfets on the inputs.
Old 30th October 2002, 04:06 PM   #3
What happens when I use 220K resistor instead of 100K resistor in a feedback loop?
www.audiosector.com
Old 30th October 2002, 05:09 PM   #4
diyAudio Retiree
Default What happens when I use 220K resistor instead of 100K resistor in a feedback loop?
Your gain is 2.2 times as high all else being equal.
Fred
Old 30th October 2002, 05:23 PM   #5
jam is offline jam  United States
jam's Avatar
Fred,
Would your bandwidth not also change, and what about distortion? Any thoughts?
Jam
Old 30th October 2002, 05:28 PM   #6
Thanks for enlightening me. It seems that I'm not the only one who lost it.
So I guess too much gain is not good and I better stick with 100K. What would be recommended value of resistance devider at the input. I was hoping for 10K series, 68K to ground, because this would work really well with my silver foil 0.022uF filter cap, providing cut off frequency around 120Hz (high pass). But isn't 68K a bit high for input ground resistor? I'm just putting it together BTW.
www.audiosector.com
Input Impedance Bengali Analog Line Level 7 15th August 2007 10:24 PM
Input impedance nhuwar Tubes / Valves 24 23rd July 2007 11:11 PM
anyone tried up aleph x input impedance? elviukai Pass Labs 14 19th March 2007 11:48 PM
How much input impedance is enough? Russ White Chip Amps 5 13th April 2005 07:25 PM
Increasing Aleph 3 input impedance Freddie Pass Labs 5 29th August 2001 10:52 PM
Page generated in 0.08735 seconds (73.51% PHP - 26.49% MySQL) with 10 queries
