Old 21st December 2005, 11:48 PM   #1
Default Aleph-X transformer
I am testing my Aleph-X . The PS is consist of 2 x 600 kVA tranformers with 2 groups of 110V primary tapping, the secondary is 16 Vac. Unfortunally, I have blown one of the 110 V core group in one transformer.
can I serial the two transformers, by using the still working 110V core group with another 110V core from the second good transformer to get it working under 230V ?
Old 25th December 2005, 10:07 AM   #2
How did you manage to blow one primary ?
If you have overloaded the trafo enough to blow
a winding I would suspect that the insulation is
severly damaged also.
In this case it has to be rewound.
(you don't want to try rewinding a toroid though...)
You can probably connect them in series if they both
see the same load, beware that your VA rating would
be halfed.
(the single winding on the damaged trafo can only take
half the current)
/Kenny
aleph X transformer ? jeclk Pass Labs 3 20th October 2005 10:33 PM
Help - Transformer for Aleph 3 vsr123 Pass Labs 4 11th March 2003 05:04 PM
Aleph 5 transformer billy Pass Labs 7 26th July 2002 07:50 PM
transformer voltage needed for Aleph 4 or Aleph 2 diy student Pass Labs 23 28th November 2001 07:54 PM
Page generated in 0.06836 seconds (67.96% PHP - 32.04% MySQL) with 10 queries
