#11 |
sweet
![]() be sure to send some pics to PassDIY, this amp deserves to be in the Gallery! |
#12 |
The one and only
Speaking of which, here was the view in SF sitting behind
Phil Lesh. |
#13 |
The one and only
And here was our most of our enthusiastic female contingent:
#14 |
[QUOTE]Originally posted by chipco3434
[B]I see an aluminum brdge that appears to be spanning the two voltage rails... going from cap+ to cap- I don't understand that part. Dear chipco, Please look very carefully to the frontdetail picture. Sorry for the low resolution(100k max). At the left and right front side(vertical) you see two rectifier bridges(discrete). The brown wire(left) is the +20V. The blue wire(right) is the -20V. The two green/Yello wires connect the two bridges at the large aluminium bridge above the cappacitors. This is my 0V starground point. The supply has a CLC filtering. Mechanical from the outsides to the middle. 2x22000uF- 2,2mH-2x22000uF. I hope it's clear if not i must look for another picture. Johan. |
#15 |
[QUOTE]Originally posted by audiotux
[B]nice work Johan ! beautyful blue Power-Cord too ! Greetings from Germany Dear Jürgen, Believe it or not. It's no Siltech cabel(i have no Siltech money) It's a real Gronenberg. Made in Germany!!! Gr. Johan. |
#16 | |
Mayby this amp can help him with his "Satisfaction"problem. Otherwise "some like it hot" By the way. It's not for sale. Gr. Johan. |
#17 |
some more details ...
#18 |
Oh, I get it now.
#19 |
Account Disabled
Heavy copper loading made the blue caps buckled . . . ?
#20 | |
Yes you must be very secure. Friction can be deadly. Otherwise the BC 154 serie looks mechanical very strong. It’s M5. If you want to go for safe use a printboard. |
| "sensorless" soldering iron temperature control | star882 | Parts | 3 | 24th May 2009 08:44 AM |
| The "Leap-Frog" Method Of Switching Amplifier Control Loop Design | analogspiceman | Class D | 29 | 1st December 2006 03:21 PM |
| Where does "fullrange" end and "two-way" start? | KCHANG | Full Range | 55 | 1st December 2006 08:21 AM |
| At which frequency does "ear canal gain" start for headphones? | 454Casull | Multi-Way | 7 | 15th July 2004 09:04 AM |
| How to make relais volume control | till | Digital Source | 27 | 19th September 2003 06:02 PM |
