Treshold Stasis S300 Vs Aleph 30 - Page 4 - diyAudio
Old 5th February 2007, 02:26 AM   #31
AR2 is offline AR2  United States
Master Burner
AR2's Avatar
Here is the process of feet making. This was piece of 4" aluminum machined to 3" and now bored for plastic insert, that will protect floor from scratching.
Old 5th February 2007, 02:53 AM   #32
Master Burner
AR2's Avatar
My wife did her part and gave me chopping board that ended up chopped.
Old 5th February 2007, 02:55 AM   #33
Master Burner
AR2's Avatar
Drilling with all pieces in the background.
Old 5th February 2007, 02:58 AM   #34
Master Burner
AR2's Avatar
Finished foot. All that is left is polishing and powder coating. They will be too distracting if left shiny, so I decided to have them black.
Old 5th February 2007, 03:00 AM   #35
Master Burner
AR2's Avatar
I am not able to edit previous posts, so here are bigger shots of the work in progress.
I sand blasted sinks that are going to be powder coated.
Old 5th February 2007, 03:01 AM   #36
Master Burner
AR2's Avatar
And one more.
Old 5th February 2007, 03:15 AM   #37
Master Burner
AR2's Avatar
Surface milling of the heat sink in order to achieve best heat transfer. I will additionally sand this surface with 2500 grit sanding paper for real mirror like surface.
Old 5th February 2007, 03:24 AM   #38
diyAudio Moderator Emeritus
roddyama's Avatar
AR2,
It looks as if you have a machine shop at your disposal. Maybe you have a smallish granite surface plate too, maybe 12"sq or 18"sq. If you do, when you sand the surface of the heatsinks, put the sandpaper on the plate in a laundry sink and move the heatsink over the paper while running water over it. This will give u a better finish and hold the paper to the plate too.
BTW, The amp is looking great.
Rodd Yamashita
Old 5th February 2007, 03:31 AM   #39
Master Burner
AR2's Avatar
Thank you Rodd. Yes I do have big granite slab (compliments from Grizzli Industrial) and a small one for the purpose you described.
I have been experimenting with various grits and I completely agree with you. Finishes are much better with water, and wet sending is must with those fine grits. Water prevents loading of the sand paper as well, that otherwise would be wasted in no time.
Old 5th February 2007, 03:41 AM   #40
Hi AR2,
Your amplifier looks great! Where did you buy those heatsinks?
How much did they cost?
NAD S300 int amp problem hifienthusiast Solid State 33 27th November 2016 10:34 AM
NAD s300 HFERRAO Parts 0 10th May 2009 11:44 PM
Nad S300 DFroehlich Swap Meet 1 7th April 2008 03:51 AM
Best bias for 400a/S300? centaurus3200 Pass Labs 2 20th April 2007 11:12 PM
Theshold S300 Amp Gwiesner Parts 0 17th November 2006 06:51 PM
Copyright ©1999-2017 diyAudio
