I am pondering using 250uF 165V Aero M metalized polypropylene motor start capacitors in a mini A / Aleph 30. They will be bypassed with 56nF polystyrenes.
I plan on pulling "R19" so figured the larger "C10" cap wouldnt hurt too much. I could also change "R21". I am not concerned about the caps size, except as it possibly relates to electrical performance. Do I lose anything versus the Jleaman (thanks!!) supplied 220uF 35V 105C Nichicons?
Be sure your foil hat has a good low impedance ground. |
#2 |
motor RUN caps are OK
motor START aren't search
my Papa is smarter than your Nelson ! tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
#3 |
The negative stuff Ive seen searching on motor starts was on electrolytic ones, these are not.
Ive got 92uF oil caps, but pairs of those would bigger than the rest of the amp combined. Also, lead length would be pretty long.
#4 |
OK-just try it
| if you all had a choice to start again what.... | PixelPlay | Pass Labs | 18 | 29th January 2007 08:53 AM |
| Capacitor choice | Pierre | Class D | 7 | 17th August 2005 08:02 PM |
| AC Motor Start Caps for PS use | gilid | Tubes / Valves | 44 | 28th June 2004 11:35 PM |
| Help with capacitor choice. | Fin | Digital Source | 7 | 8th June 2004 07:26 AM |
