I ordered mine from www.conradheatsinks.com. Total price for 4 double MF30-2F was about 1600NOK(freight included). Cheaper than anything that I found in Norway or Scandinavia.
Llafriel
How much heat do you dissipate in your heatsinks and how hot does they run and at what room temp.
I would sure like to know a bit about your experience on the heatsinks, which amp and wattage....
PS: Perhaps you could post some pictures or something.
Feel free to email me
I'll be using them for an Aleph 5, two pr. channel. The Aleph 5 dissipates 150W pr. channel. Mine isn't finished yet, but you could look this page for some measurments.
http://www.users.on.net/~mefinnis/passlabs/aleph5_construction.htm
He's using one sink pr. channel and the temperature is 70C. The sink is MF30-2F.
If its the same as I bought from him, mine didn't need milling. But lots of work to finish the chassis. Does they look like these?I have an offer from Magura
If you go for the Conrads, simply buy the biggest you can get, and if you consider a high power version A-X, get enough for monoblocks
Steen
Steenoe
Jup, that's the ones
He's trying to get 12 of them for me.
Are your Amp's on the pics Aleph-X's or other.
How much are you able to drive with those baby's and how much do they dissipate ?
Do you have some close up pictures and some pictures from inside the amp's ?
PS: Did you get my email about some other pcb's ?
Yes, I am building 100 watts A-X's.Are your Amp's on the pics Aleph-X's or other.
I dont know the excact dissipation figure for those sinks. My guess is that a monoblock like those on the pic, can dissipate a bit more than the 300 watts per channel my A-X's are gonna dissipate. Those sinks are pretty good, with fins on both sides of the body, which is thick.How much are you able to drive with those baby's and how much do they dissipate ?
The amps are not quite finished yet. Here is a pic of the chassis, in the making. Those sinks are just coolDo you have some close up pictures and some pictures from inside the amp's ?
No, but I dont get any of those "Reply to post" mails from DIYaudio at the moment either. Maybe its the mailsystem here?Did you get my email about some other pcb's ?
I will mail you instead
Its not too cold yet, Jurgen I hope to get them running before winter sets in for real. They might be able to heat up the livingroomthere must be cold in the nord of europe !
Steen
I will post one more pic for you, since these heatsinks are not excactly the easiest ones to construct a chassis from. Here is how I have bolted it together, seen from inside. I had bushings machined for the bolt holes in the sinks, but I dont think, thats really necessary. If you need more pics or other info, let me know
Steen
Steen
I'm using the www.conradheatsinks.com model MF350-151.5
I bought four of them and the total shipping cost was only $15USD!!!
Consider the larger heatsinks with a thicker base. Corrected for room operating temperature the thermal rating was .295 c/w.
I took the spec value of .21c/w and multiplied it by 1.4 to get .295c/w.
Their flanged models have a slightly thinner base and slightly greater thermal rating.
Consider the larger models at 350mm rather than 300mm.
Good luck.
-David
Good luck.
-David
- Heatsinks
