BOSOZ help needed - Page 2 - diyAudio
Old 10th December 2005, 09:01 AM   #11
lgreen is offline lgreen  United States
lgreen's Avatar
Originally posted by AR2
Unfortunate. And I have 6 boards!!!
6 boards, lucky you! I am starting to think that it would have been easier to have 0 boards and hand-wire everything.
Old 10th December 2005, 11:40 AM   #12
steenoe is offline steenoe  Denmark
steenoe's Avatar
Lgreen, just a thought. Do you use singleended input? If yes, did you remember to connect the -IN to GND then? Otherwise it wont say anything!
Steen
Old 10th December 2005, 12:28 PM   #13
dhole is offline dhole  United Kingdom
dhole's Avatar
Hi Guys
Yeah I got mine working just fine. Apart from the diode situation there are also some diodes on the rectifier board the wrong way round. again that is in the thread (" heatsinks for bosoz "I think)
Yeah I used Mikkels input selector board and volume control. Im just putting the finishing work to the case today.... Will post when complete.
regards
dave
The luminous space in the Sword of Orion...
Old 10th December 2005, 09:05 PM   #14
lgreen's Avatar
Default working!
Ok, I got it working. Turns out my negative 6.5V power supply was not sufficiently negative to turn the transistors on.
todays changes
- changed the edgemost 3.6v zener diode in negative supplies from 3.6 to 9.1v, unloaded supply is now 10.1 V, loaded is 9.2 V. This is weird, I've got 2 zeners about 3 and 4 v each, plus a 9.1 zener and all i get is 10v out unloaded.
- added 39K 1/4W resistor (positive) and 2K (negative) to ground at output of power supplies to dissipate/load power supplies when power is turned off.
measurements-
- Positive CRC filter in operation drops 93.3V to 88.8 V.
- Positive regulator outputs 60.1V from 88.8 V, runs at +44 degrees C in free air.
Looks like its working for now anyway. got a few things to do but will post pictures.
FYI, the + rail just doesn't drop when you disconnect power, so I think its very important to have a bleed resistor somewhere on the + supply.
Old 12th December 2005, 03:21 PM   #15
SteveA is offline SteveA  United States
Default lgreen
What value caps did you use in your power supply (I also got 6 sets of boards)? I have a bunch of 1000uF/100v caps from both a simple BOSOZ and Aleph P1.7 projects left over. Do I gain anything by going to, eg, 4700uf?
Thanks,
SteveA
Old 12th December 2005, 05:43 PM   #16
lgreen's Avatar
Default Re: lgreen
Thanks,
SteveA
I used CRC = 2200 - 47R - 2200 in for positive; CRC = 4700 - .5R - 4700 in the negative supply.
Here is a large hires picture of the power supply. Counting everything there are 8 regulated power supplies in there.
I have no idea why the boards are sized for 4700 uF capacitors but that's overkill. Then again, this design uses 5 MOSFETs per channel instead of the 2 in the original, so maybe you need more?? But think about the fact that the original supply was supposed to be for 2 channels, so by using separate boards for each channel you are effecively already doubling the capacitance.
Essentially, I'm not an expert on this but I'd feel ok with 1000 uF if I had dual mono boards (1 supply for 1 channel).
I listened to it for about 20 minutes late late last night-- is it me or is the gain on this less than with the bosoz?
Anyone know what the gain is?
Old 13th December 2005, 05:26 PM   #17
Default transformer(s)
lgreen-
I neglected to ask what transformer(s) you used in the power supply? Do you have a recommendation?
Thanks,
SteveA
Old 13th December 2005, 09:48 PM   #18
lgreen's Avatar
Default Re: transformer(s)
lgreen-
Thanks,
SteveA
two different answers
I used a plitron 60-0-60 wired in parallel for each + rail and another transformer with multiple secondaries for the negative rails.
I don't recommend this, as 60-0-60 is a little too high for the voltages you need.
I cannot see why people dont start a stampeded to buy out all of these surplus transformers at Parts Express $29.68
quote:
This multi-tap toroidal transformer is excellent for power amp building, and offers extra possibilities thanks to its multiple output voltages. 55V-0-55V 350VA output will run a power amplifier, 16.2V-0-16.2V output can be used for powering a pre-amp or EQ section, and 14V output can be used to power a cooling fan. Factory buyout - limited quantity!
One transformer is sufficient for dual mono supplies. Its a no brainer.
To BOSOZ or not to BOSOZ... please comment. spence Pass Labs 4 27th February 2012 03:57 AM
Help needed ! Inter M R300 schematics needed ! alexclaire Solid State 30 9th September 2009 07:14 AM
Poll! What do you use in your X-BOSOZ or BOSOZ for Volume Control and Input Selector? promitheus Pass Labs 87 19th February 2006 04:15 PM
X-bosoz vs. CCS X-bosoz, how does the sound compare? acliao Pass Labs 14 26th February 2004 01:55 AM
Bosoz lawbadman Pass Labs 5 14th July 2003 03:10 AM
Copyright 1999-2017 diyAudio
