Old 9th December 2005, 01:42 PM   #1
Default Mini-A Power question
Would a 400VA (2x12V@200VA) run four channels of Mini-A?
Power supplies are 2x66,000uF CRC.
Old 9th December 2005, 02:08 PM   #2
MikeW is offline MikeW  United States
MikeW's Avatar
It depends on the bias you want to run.
MikeW
Old 9th December 2005, 02:22 PM   #3
er ah... standard...
I am using the Brian GT board and did not plan on upping the bias. I am not sure what the "standard" bias resistor was in the kit, but that's what I'm running.
I am planning on running this as a bi-amp four channel. I guess I could give something up to lower the bias on the HF amp if it was important.. close???
Or should I just buy another tranny?
Old 9th December 2005, 06:48 PM   #4
MikeW's Avatar
If you bias them at 1.5 amps with 14.5 volt rails it will be about 44 watts per channel. A 400VA or 2-200VA should do it.
Wuffwaff (William) has an Aleph power spreadsheet on this forum somewhere.
MikeW
Old 9th December 2005, 07:11 PM   #5
Thanks... my feeling is that it's a little low... just approaching marginal. Sometimes you get clarity after you can sleep on it. I got the dough... I should just buy the second one (tranny) rather than kicking myself in the a$$ every *******' time I look at it for the next twenty years. Eh?
I will check wuffwaff's power calculator though. Thanks!
mini aleph transformer question wicked1 Pass Labs 3 8th July 2009 11:03 PM
Mini EQ (sorta) question. JoeBob Multi-Way 10 8th December 2008 09:13 PM
Houston Mini 2004 Pot question p.heimpold Tubes / Valves 5 9th August 2007 09:37 PM
Mini Aleph PS question randytsuch Pass Labs 0 3rd October 2006 04:02 PM
ccs question on mini A jeapel Pass Labs 16 29th August 2005 02:29 AM
Page generated in 0.06792 seconds (71.64% PHP - 28.36% MySQL) with 10 queries
